Messaging Gateway
 SMG platform in virtual appliance - Maximum capacity for sending and receiving emails
Carlos Barahona's profile image
Carlos Barahona posted Dec 02, 2024 10:57 AM
Can you help me with this question for the SMG platform in virtual appliance?
What is the maximum number of emails that can be sent and received per month and per day?
alexander smg's profile image
alexander smg
what is the cpu and ram count for your appliance?  Since i run the largest smg farm in the world, i can run easily 200,000 emails outbound alone per hour per device.  Note, that if you have high queuing rates (either you are throttled or denied sending), this greatly affects your performance.  If you loadbalance connections across multiple smg's, u gain even greater performance.
Bottom line, use only virtual appliances with the most ram and cpu you can afford.
