Data Loss Prevention
 DLP Network Prevent for Web - Inspecting WebSocket Traffic
Andre Iseli's profile image
Andre Iseli posted Apr 24, 2025 04:38 AM
Dear all
Is it possible to intercept websocket traffic from an application towards a cloudservice via a proxy and perform a DLP inspection via Network Prevent for Web or does that require some sort of CASB solution?
Thanks
André
Barnabas Toth's profile image
Barnabas Toth
Hi Andre,
As long the traffic goes through the http/s proxy it does not matter whether it is originating from a browser or an app. It will be forwarded via ICAP to web prevent for inspection.
Regards,
Barnabas
Tobias Pischl's profile image
Broadcom Employee Tobias Pischl
Hi André,
we are looking at options to inspect websocket traffic. In case can you message me the use case you have to ensure we can capture it correctly with the current designs we are looking at?
At the moment it would likely be dependent on CASB Gateway to make proper sense of the websocket interactions to enable meaningful DLP.
Thanks,
toby
