DX Infrastructure Management
Tech Tip: UIM - baseline_engine error when trying to open the probe via Admin Console. unable to read configuration, Error Code: PPM-020
Mar 13, 2017 04:14 PM
Document ID:  TEC1798794
Last Modified Date:  12/22/2016
Show Technical Document Details
Problem:
The baseline_engine probe generates a popup error when trying to open (Configure) the probe.
"Unable to read configuration, Error Code: PPM-020
Configuration was unable to be retrieved.
Message: Server Error: Unsupported adapter request for probe at address /<hub>/<domain>/<robot>/baseline_engine
Resolution: Please use either the Thick Client or Raw Configure for this probe
Error Code: PPM-020
This probe may not support this configuration. Click Raw Configure to configure using Raw Configure.
Click Retry to attempt to save you configuration again, Click Close to close the Window."
Environment:
- UIM 8.47 - baseline_engine v2.76
Cause:
The underlying cause is actually stated in the popup error message itself.
"Please use either the Thick Client or Raw Configure for this probe." The baseline_engine only opens in Raw Configure mode in the Admin Console.
Resolution:
The baseline_engine probe can only be configured using the Infrastructure Manager (IM) thick client or in the Admin Console via Raw Configure mode, not a GUI window.
Statistics
0 Favorited
0 Files
0 Shares
0 Downloads
Tags and Keywords
Related Entries and Links
No Related Resource entered.
