DX Unified Infrastructure Management
  • 1.  Problem recalculating SLAs
    Posted 13 days ago
    Hello,
    We have a problem when we recalculate an SLA. When the period is all day, the recalculation is done well, but when we recalculate only a few hours of the day, the recalculation does not work.
    For example:
    This is the excluded period
    and this is the recalculate
    This example doesn´t work, but if the excluded period is the whole day, it does work.
    Thanks for your help.
  • 2.  RE: Problem recalculating SLAs
    Posted 10 days ago
    Hi,
    which version of the sla_engine do you run?
  • 3.  RE: Problem recalculating SLAs
    Posted 10 days ago
    Hello,
    The SLA engine version is 20.11.
    Thnaks.
  • 4.  RE: Problem recalculating SLAs
    Posted 10 days ago
    Hi,
    20.11 is really old. Since we have seen a similar problem with 20.41, it might already exist with 20.11.
    As soon as you use Office Hours in the SLA, it happens that the calculation uses wrong time periods. If I remember correctly, the calculation periods are offset by one day. With a higher log level (I guess loglevel=4) you can see this nicely in the logfile (but unfortunately you have to convert EPOCH timestamps).
