Thanks for the update Shalini.
Much appreciated.
Regards
Sankar
On Fri, 17 Nov, 2023, 20:21 Shalini Murukes via Broadcom, <
mail@broadcom.com>
wrote:
> Hi Sankar, I am able to get response even without the line in the
> local.properties file in {LISA_HOME} . So , the issue was with the type
> of...
> [image: Broadcom] <https: community.broadcom.com="">
> Service Virtualization
> <https: community.broadcom.com/enterprisesoftware/communities/community-home/digestviewer?communitykey="94bda077-625b-4914-8ac3-c88a06c2cc23">
> Post New Message <
broadcom-servicevirtualization@connectedcommunity.org>
> Re: Mule Soft endpoint for REST API call with SSL certificate -
> java.net.SocketException: Connection reset by peer: socket write error
> <https: community.broadcom.com/enterprisesoftware/discussion/mule-soft-endpoint-for-rest-api-call-with-ssl-certificate-javanetsocketexception-connection-reset-by-peer-socket-write-error#bmfd7668c1-5c94-4c7f-a655-018bddc00ee0="">
> Reply to Group
broadcom_servicevirtualization_fd7668c1-5c94-4c7f-a655-018bddc00ee0@connectedcommunity.org?subject=re:+mule+soft+endpoint+for+rest+api+call+with+ssl+certificate+-+java.net.socketexception:+connection+reset+by+peer:+socket+write+error> Reply
> to Sender
> <https: community.broadcom.com/enterprisesoftware/communities/all-discussions/postreply?messagekey="fd7668c1-5c94-4c7f-a655-018bddc00ee0&ListKey=d4484a56-be7e-428f-99d1-26cc0f5a617e&SenderKey=65e1ec20-76b9-4608-92ca-171ed3297893">
> [image: Shalini Murukes]
> <https: community.broadcom.com/network/members/profile?userkey="65e1ec20-76b9-4608-92ca-171ed3297893">
> Nov 17, 2023 9:52 AM
> Shalini Murukes
> Hi Sankar,
> I am able to get response even without the line in the local.properties
> So , the issue was with the type of certificate used.
> Thank You !!
> *Reply to Group Online
> <https: community.broadcom.com/enterprisesoftware/communities/all-discussions/postreply?messagekey="fd7668c1-5c94-4c7f-a655-018bddc00ee0&ListKey=d4484a56-be7e-428f-99d1-26cc0f5a617e">*
> *Reply to Group via Email
broadcom_servicevirtualization_fd7668c1-5c94-4c7f-a655-018bddc00ee0@connectedcommunity.org?subject=re:+mule+soft+endpoint+for+rest+api+call+with+ssl+certificate+-+java.net.socketexception:+connection+reset+by+peer:+socket+write+error>*
> *View Thread
> <https: community.broadcom.com/enterprisesoftware/discussion/mule-soft-endpoint-for-rest-api-call-with-ssl-certificate-javanetsocketexception-connection-reset-by-peer-socket-write-error#bmfd7668c1-5c94-4c7f-a655-018bddc00ee0="">*
> *Recommend
> <https: community.broadcom.com:443/enterprisesoftware/discussion/mule-soft-endpoint-for-rest-api-call-with-ssl-certificate-javanetsocketexception-connection-reset-by-peer-socket-write-error?messagekey="fd7668c1-5c94-4c7f-a655-018bddc00ee0&cmd=rate&cmdarg=add#bmfd7668c1-5c94-4c7f-a655-018bddc00ee0">*
> *Forward
> <https: community.broadcom.com/enterprisesoftware/communities/all-discussions/forwardmessages?messagekey="fd7668c1-5c94-4c7f-a655-018bddc00ee0&ListKey=d4484a56-be7e-428f-99d1-26cc0f5a617e">*
> *Flag as Inappropriate
> <https: community.broadcom.com/enterprisesoftware/discussion/mule-soft-endpoint-for-rest-api-call-with-ssl-certificate-javanetsocketexception-connection-reset-by-peer-socket-write-error?markappropriate="fd7668c1-5c94-4c7f-a655-018bddc00ee0#bmfd7668c1-5c94-4c7f-a655-018bddc00ee0">*
> Original Message:
> Sent: Nov 17, 2023 09:16 AM
> From: Sankar Natarajan
> Subject: Mule Soft endpoint for REST API call with SSL certificate -
> Hi Shalini
> Thats what I want to establish. If the original problem is solved
> because of the presence/absence of the property: lisa.server.https.cipher.
> suites.
> Since you had a problem in passing the keystore, I want to clearly
> understand which step helped solve the problem.
> regards
> Sankar Natarajan
> This electronic communication and the information and any files transmitted
> with it, or attached to it, are confidential and are intended solely for
> the use of the individual or entity to whom it is addressed and may contain
> information that is confidential, legally privileged, protected by privacy
> laws, or otherwise restricted from disclosure to anyone else. If you are
> not the intended recipient or the person responsible for delivering the
> e-mail to the intended recipient, you are hereby notified that any use,
> copying, distributing, dissemination, forwarding, printing, or copying of
> this e-mail is strictly prohibited. If you received this e-mail in error,
> please return the e-mail to the sender, delete it from your computer, and
> destroy any printed copy of it.
> Original Message:
> Sent: 11/17/2023 9:06:00 AM
> From: Shalini Murukes
> Subject: RE: Mule Soft endpoint for REST API call with SSL certificate -
> Hi Sankar,
> I will comment the above line in the local.properties in the {LISA_HOME}
> and then try running the script.
> But I am curious to know, will it work even without this line in the
> property file ?
> Original Message:
> Sent: Nov 17, 2023 04:30 AM
> Thanks for the update. Can you please repeat the test by commenting out the
> following property that you added to local.properties file.
> lisa.server.https.cipher.suites=TLS_DHE_RSA_WITH_AES_
> 128_CBC_SHA,TLS_DHE_RSA_WITH_AES_128_CBC_SHA256,TLS_DHE_
> RSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_RSA_WITH_AES_128_
> CBC_SHA,TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256,TLS_ECDHE_
> RSA_WITH_AES_128_GCM_SHA256,TLS_RSA_WITH_AES_128_CBC_SHA,
> TLS_RSA_WITH_AES_128_CBC_SHA256,TLS_RSA_WITH_AES_128_GCM_SHA256
> NOTE: Please restart workstation after commenting out the property.
> regards
> Sankar Natarajan
> Original Message:
> Sent: 11/17/2023 4:25:00 AM
> Hi Sankar,
> The issue is resolved. I certificate had .p12 as extension, instead of
> .pfx. After changing that, it worked correctly.
> Thank You so much for your effort in finding a solution for the issue.
> Original Message:
> Sent: Nov 17, 2023 02:54 AM
> HI Shalini
> The log file has been reviewed. Please follow the procedure below
> and let me know if it solves the reported issue:
> 1. On the Workstation Machine, open the file LISA_HOME/local.properties in
> a text editor
> 2. Add the following property
> 3. Save the file and restart workstation
> 4. Repeat the test and let me know the outcome
> 5. If the problem persists. then please share the workstation log file for
> further analysis
> regards
> Sankar Natarajan
> Original Message:
> Sent: 11/16/2023 1:10:00 PM
> Hi Sankar,
> I have followed the steps you mentioned and have posted the log file for
> your analysis as a private message to your inbox.
> Original Message:
> Sent: Nov 16, 2023 09:13 AM
> Hi Shalini
> Can you do the following to diagnose this further.
> - Edit the file workstation.vmoptions in LISA_HOME/bin folder
> - Add the following line and save the file
> - -Djavax.net.debug=ssl
> - Restart Workstation and repeat the test
> - Share the workstation.log file from USER_HOME/lisatmp_x.x.x folder for
> analysis
> regards
> Sankar Natarajan
> Original Message:
> Sent: 11/16/2023 8:44:00 AM
> Hi Team ,
> Our project is using Mulesoft Endpoint for the REST API calls. I am using
> SSL certificate, for which I have mentioned the details in the
> local.properties file in my workstation.
> ssl.client.cert.path=C:\\Users\\12345\\DevTest\\Projects\\samplecert.com.pfx
> ssl.client.cert.pass=password
> https.protocols=TLSv1.2,TLSv1.1,TLSv1
> lisa.net.trustStore=C:\\Users\\12345\\DevTest\\Projects\\samplecert.com.jks
> lisa.net.trustStore.password=password
> Note : Same password is used for the .pfx and .jks file.
> When I try to run the sample test case in ITR mode, I get the below error
> . Please let me know what can be done to fix this.
> | HTTP
> | Step: AddCustomer
> | Message: java.net.SocketException: Connection reset by peer: socket
> write error
> | Trapped Exception: Connection reset by peer: socket write error
> | Trapped Message: java.net.SocketException: Connection reset by peer:
> socket write error
> STACK TRACE
> at java.net.SocketOutputStream.socketWrite0(Native Method)
> at
> java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:111)
> at java.net.SocketOutputStream.write(SocketOutputStream.java:155)
> at sun.security.ssl.OutputRecord.writeBuffer(OutputRecord.java:431)
> at sun.security.ssl.OutputRecord.write(OutputRecord.java:417)
> at
> sun.security.ssl.SSLSocketImpl.writeRecordInternal(SSLSocketImpl.java:879)
> at sun.security.ssl.SSLSocketImpl.writeRecord(SSLSocketImpl.java:850)
> at sun.security.ssl.SSLSocketImpl.writeRecord(SSLSocketImpl.java:720)
> at
> sun.security.ssl.Handshaker.sendChangeCipherSpec(Handshaker.java:1144)
> at
> sun.security.ssl.ClientHandshaker.sendChangeCipherAndFinish(ClientHandshaker.java:1333)
> at
> sun.security.ssl.ClientHandshaker.serverHelloDone(ClientHandshaker.java:1243)
> at
> sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:373)
> at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1037)
> at sun.security.ssl.Handshaker.process_record(Handshaker.java:965)
> at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1064)
> at
> sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1367)
> at
> sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1395)
> at
> sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1379)
> at
> org.apache.http.conn.ssl.SSLSocketFactory.connectSocket(SSLSocketFactory.java:535)
> at
> org.apache.http.conn.ssl.SSLSocketFactory.connectSocket(SSLSocketFactory.java:403)
> at
> org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:177)
> at
> org.apache.http.impl.conn.ManagedClientConnectionImpl.open(ManagedClientConnectionImpl.java:304)
> at
> org.apache.http.impl.client.DefaultRequestDirector.tryConnect(DefaultRequestDirector.java:611)
> at
> org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:446)
> at
> org.apache.http.impl.client.AbstractHttpClient.doExecute(AbstractHttpClient.java:863)
> at
> org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:72)
> at com.itko.lisa.test.CommTrans.doSend(CommTrans.java:1082)
> at com.itko.lisa.test.CommTrans.send(CommTrans.java:851)
> at com.itko.lisa.test.CommTrans.sendPOST(CommTrans.java:811)
> at com.itko.lisa.ws.rest.RESTNode.doSend(RESTNode.java:226)
> at com.itko.lisa.ws.rest.RESTNode.doWebTrans(RESTNode.java:171)
> at com.itko.lisa.ws.rest.RESTNodeBase.execute(RESTNodeBase.java:380)
> at com.itko.lisa.test.TestNode.executeNode(TestNode.java:995)
> at com.itko.lisa.test.TestCase.execute(TestCase.java:1297)
> at com.itko.lisa.test.TestCase.execute(TestCase.java:1198)
> at com.itko.lisa.test.TestCase.executeNextNode(TestCase.java:1183)
> at
> com.itko.lisa.utils.ExecSubProcessNode.doFullExec(ExecSubProcessNode.java:354)
> at
> com.itko.lisa.utils.ExecSubProcessNode.execute(ExecSubProcessNode.java:268)
> at
> com.itko.lisa.editor.WalkThruPanel.prepAndExecNode(WalkThruPanel.java:1120)
> at
> com.itko.lisa.editor.WalkThruPanel.access$900(WalkThruPanel.java:73)
> at
> com.itko.lisa.editor.WalkThruPanel$10.doCallback(WalkThruPanel.java:1022)
> at
> com.itko.util.swing.panels.ProcessingDialog$2.run(ProcessingDialog.java:195)
> at java.lang.Thread.run(Thread.java:748)
> Shalini Murukes
> You are subscribed to "Service Virtualization" as
sankar.natarajan@broadcom.com. To change your subscriptions, go to My
> Subscriptions
> <http: community.broadcom.com/preferences?section="Subscriptions">. To
> unsubscribe from this community discussion, go to Unsubscribe
> <http: community.broadcom.com/higherlogic/egroups/unsubscribe.aspx?userkey="36e7cc73-528a-48f6-8c4b-455a0e4cdb59&sKey=KeyRemoved&GroupKey=d4484a56-be7e-428f-99d1-26cc0f5a617e">.
> Copyright © 2005-2023 Broadcom. All Rights Reserved. The term "Broadcom"
> refers to Broadcom Inc. and/or its subsidiaries.
> Hosted by Higher Logic, LLC on the behalf of Broadcom - Privacy Policy
> <https:
www.broadcom.com/company/legal/privacy-policy=""> | Cookie Policy
> <https:
www.higherlogic.com/legal/privacy=""> | Supply Chain Transparency
> <https:
www.broadcom.com/company/citizenship/governance-and-ethics#supply="">> | Terms of Use <http: termsandconditions="">
Original Message:
Sent: 11/17/2023 9:52:00 AM
Subject: RE: Mule Soft endpoint for REST API call with SSL certificate - java.net.SocketException: Connection reset by peer: socket write error
Hi Sankar,
I am able to get response even without the line in the local.properties file in {LISA_HOME} .
Thank You !!
Original Message:
Subject: Mule Soft endpoint for REST API call with SSL certificate - java.net.SocketException: Connection reset by peer: socket write error
Hi Shalini
suites.
regards
Sankar Natarajan
Original Message:
Hi Sankar,
I will comment the above line in the local.properties in the {LISA_HOME} and then try running the script.
But I am curious to know, will it work even without this line in the property file ?
Original Message:
regards
Sankar Natarajan
Original Message:
Hi Sankar,
The issue is resolved. I certificate had .p12 as extension, instead of .pfx. After changing that, it worked correctly.
Original Message:
HI Shalini
a text editor
lisa.server.https.cipher.suites=TLS_DHE_RSA_WITH_AES_128_CBC_SHA,TLS_DHE_RSA_WITH_AES_128_CBC_SHA256,TLS_DHE_RSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA,TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256,TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256,TLS_RSA_WITH_AES_128_CBC_SHA,TLS_RSA_WITH_AES_128_CBC_SHA256,TLS_RSA_WITH_AES_128_GCM_SHA256
further analysis
regards
Sankar Natarajan
Original Message:
Hi Sankar,
I have followed the steps you mentioned and have posted the log file for your analysis as a private message to your inbox.
Original Message:
Hi Shalini
analysis
regards
Sankar Natarajan
Original Message:
Hi Team ,
Our project is using Mulesoft Endpoint for the REST API calls. I am using SSL certificate, for which I have mentioned the details in the local.properties file in my workstation.
When I try to run the sample test case in ITR mode, I get the below error . Please let me know what can be done to fix this.
| HTTP
| Step: AddCustomer
| Message: java.net.SocketException: Connection reset by peer: socket write error
| Trapped Message: java.net.SocketException: Connection reset by peer: socket write error
STACK TRACE
at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:111)
at sun.security.ssl.SSLSocketImpl.writeRecordInternal(SSLSocketImpl.java:879)
at sun.security.ssl.Handshaker.sendChangeCipherSpec(Handshaker.java:1144)
at sun.security.ssl.ClientHandshaker.sendChangeCipherAndFinish(ClientHandshaker.java:1333)
at sun.security.ssl.ClientHandshaker.serverHelloDone(ClientHandshaker.java:1243)
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:373)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1367)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1395)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1379)
at org.apache.http.conn.ssl.SSLSocketFactory.connectSocket(SSLSocketFactory.java:535)
at org.apache.http.conn.ssl.SSLSocketFactory.connectSocket(SSLSocketFactory.java:403)
at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:177)
at org.apache.http.impl.conn.ManagedClientConnectionImpl.open(ManagedClientConnectionImpl.java:304)
at org.apache.http.impl.client.DefaultRequestDirector.tryConnect(DefaultRequestDirector.java:611)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:446)
at org.apache.http.impl.client.AbstractHttpClient.doExecute(AbstractHttpClient.java:863)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:72)
at com.itko.lisa.utils.ExecSubProcessNode.doFullExec(ExecSubProcessNode.java:354)
at com.itko.lisa.utils.ExecSubProcessNode.execute(ExecSubProcessNode.java:268)
at com.itko.lisa.editor.WalkThruPanel.prepAndExecNode(WalkThruPanel.java:1120)
at com.itko.lisa.editor.WalkThruPanel.access$900(WalkThruPanel.java:73)
at com.itko.lisa.editor.WalkThruPanel$10.doCallback(WalkThruPanel.java:1022)
at com.itko.util.swing.panels.ProcessingDialog$2.run(ProcessingDialog.java:195)
Shalini Murukes
</http:></https:></https:></https:></http:></http:></https:></https:></https:></https:></broadcom_servicevirtualization_fd7668c1-5c94-4c7f-a655-018bddc00ee0@connectedcommunity.org?subject=re:+mule+soft+endpoint+for+rest+api+call+with+ssl+certificate+-+java.net.socketexception:+connection+reset+by+peer:+socket+write+error></https:></https:></https:></https:></broadcom_servicevirtualization_fd7668c1-5c94-4c7f-a655-018bddc00ee0@connectedcommunity.org?subject=re:+mule+soft+endpoint+for+rest+api+call+with+ssl+certificate+-+java.net.socketexception:+connection+reset+by+peer:+socket+write+error></https:></broadcom-servicevirtualization@connectedcommunity.org></https:></https:></mail@broadcom.com>
