I've had cases where the NAS queue (or any other Queue) was backlogged and there is no way to monitor the Queues within UIM.
I was able to write a PowerShell script to call the WEB API on the Primary Hub and get the results, then parse through them to get the Queue Information.
If it's any queue but NAS, you could set this up in Logmon and execute the PowerShell script & setup a watch for the "Queued" number going higher than a certain Number. If you're monitoring the NAS Queue, then you're probably best off by making a Scheduled Task & setting up an email to notify yourself.
I'm giving you 99% of the code & you just need to customize it for your environment.
PowerShell Code:
function Rest-POST ($URI, $Content, $Body, $Credentials, $Timeout)
if ($Timeout -lt 0 -or $Timeout -eq "") {$Timeout = 60}
$Results = Invoke-RestMethod -Uri $URI -ContentType $Content -Method Post -Body ($Body) -Credential $Credentials -TimeoutSec $Timeout
return $Results
function UIM-GetListSubscribers ($List)
$URL = "https://UIM_Server/uimapi/probes/UIM_domain/UIM_hub/HubServer/hub/callback2/list_subscribers/30"
$Body = '{"timeout":30,"arguments":[]}'
$N = Rest-POST $URL "application/json" $Body $mycreds
for ($i = 0; $i -lt $n.nimPds.nimPdsTable.key.Count; $i++)
#Find Array Item for SUBSCRIBERS
if ($n.nimPds.nimPdsTable.key[$i] -eq "subscribers")
for ($j = 0; $j -lt $n.nimPds.nimPdsTable[$i].nimPds.Count; $j++)
# Find POSTROUTE Array AND Specific Subscribers Queue named in $LIST.
if ($n.nimPds.nimPdsTable[$i].nimPds[$j].nimString[0].'#text' -eq $List -and $n.nimPds.nimPdsTable[$i].nimPds[$j].nimString[0].key -eq "postroute")
for ($k = 1; $k -lt $n.nimPds.nimPdsTable[$i].nimPds[$j].nimInt.Count; $k++)
# Find QUEUE Count (INQ).
if ($n.nimPds.nimPdsTable[$i].nimPds[$j].nimInt.key[$k] -eq "inq")
$Queued = $n.nimPds.nimPdsTable[$i].nimPds[$j].nimInt.'#text'[$k]
# Find Total SENT Count (COUNT).
if ($n.nimPds.nimPdsTable[$i].nimPds[$j].nimInt.key[$k] -eq "count")
$Count = $n.nimPds.nimPdsTable[$i].nimPds[$j].nimInt.'#text'[$k]
#return "$List = $Queued / $Count"
return $List,$Queued,$Count
########################## MAIN ##########################
$ListSubscriber = "nas" #Could check any queue, such as: $ListSubscriber = "alarm_enrichment"
$List,$Queued,$Count = UIM-GetListSubscribers $ListSubscriber
Write-Host "UIM Queued=$Queued in ""$List"" Queue with Sent=$Count"
The output will look like this:
UIM Queued=33 in "nas" Queue with Sent=1273694
I hope you find this code helpful...
