Hi Paulo,
You must test, if you change the release. There is no guarantee that everything will work on a newer release.
I just tried the 21.0.3 May 26 build. Already seeing problems:
a) Windows Agent crashes each time a File Watcher Event job is started. - New problem.
b) The Proxy Client issue on Unix, which was supposed to be fixed in 21.0.3 is still there. The Proxy Agent on the client doesnot start.
Regards
P Verghese
Original Message:
Sent: May 26, 2022 07:08 PM
Subject: Automic Automation Engine 21.0.3 has been released and is available for download.
Hi @Mitch Denis I clicked on your link and checked the fixes. At the beginning of the same link it says to go to release notes to see a complete list, but when I compared your link's list with release notes list, I couldn't find the same fixes. For example there is the fix on the windows file event that I couldn't find on the realease list. Where I can find a complete list of differences? Also I already started testing my objects on v21.0.2 should I test everything again on v21.0.3?
Thanks!
Original Message:
Sent: May 25, 2022 04:23 PM
We also have a list of knowledge articles for issues that were reported directly to Support and an article created, found here.
Original Message:
Sent: May 23, 2022 07:07 PM
Download link and bug fixes (patch descriptions)
Compatibility matrix
Release notes
