Automic Workload Automation
Expand all | Collapse all
Automation Engine v12.3.9 HF1 removed from downloads site
  • 1.  Automation Engine v12.3.9 HF1 removed from downloads site
    Posted 12 days ago
    Edited by Michael Lowry 12 days ago
    This morning I noticed that Automation Engine v12.3.9 HF1 was is not longer available from downloads.automic.com.
    There are presently five (5) KB articles describing problems supposedly fixed by 12.3.9 HF1 .
    Adding a comment to a JOBF runid is not possible via AWI or REST API after having upgraded the AE to 12.3.9 The error displayed in AWI is the following: In the JCP, we can find the related errors: U00045014 Exception 'java.lang.NullPointerException: ....,
    Fix version: Component(s): Automation Engine Automation.Engine 12.3.9 HF1 - Available
    Solaris Agent 12.2.10 is generating cores when is it submitting File transfer. The FT jobs remains in status "Connecting" During the test period where traces where collected the agent generated 81 cores. Job trace: AIN-THREAD 20211223/082607.848 se....,
    This bug is fixed in the following releases: Hotfix: 12.3.9 HF1 of the Solaris Agent - available.
    Solaris Agent 12.2.10 is generating cores when is it submitting File transfer. During the test period the agent generated 81 can throw up to 80 cores. Job trace: AIN-THREAD 20211223/082607.848 send_IPC_internal(type=CHANNEL_CLOSE,msg(100a05e50,msgI....,
    Fix version: Component(s): Agent Unix Automation.Engine 12.3.9 HF1 - Available Automation.Engine 21.0.4 - Available
    The JCP on each of our AE nodes stopped working and in the JCP logs we are able to find many of the following error messages: U00045014 Exception 'java.lang.IllegalArgumentException: "Unable to find the fromVertex for WorkflowStructureItem{runId=1207....,
    Fix version: Component(s): Automation Engine Automation.Engine 12.3.9 HF1 - Available Automation.Engine 21.0.3 HF3 - Available Will be fixed in Automation.Engine 21.0.4 - Planned release....
    237242 JCP Rest OutOfMemoryError with Arrays.copyOf causes login impossible due to ErtEstimationResource
    This raises several questions:
    1. Why was v12.3.9 HF1 removed?
    2. Is there a serious problem with this hotfix?
    3. When will the hotfix be made available again?
    4. Alternatively, when will HF2 be made available?
    5. Also, why was an announcement not made explaining the withdrawal of this hotfix?
    Thanks in advance for prompt answers.
  • 2.  RE: Automation Engine v12.3.9 HF1 removed from downloads site
    Posted 12 days ago
    In a support ticket, I received a partial answer.
    AE 12.3.9 HF1 was temporarily withdrawn due to a problem with the Windows Agent. An updated version will be made available soon.
  • 3.  RE: Automation Engine v12.3.9 HF1 removed from downloads site
    Posted 11 days ago
    Hello Michael.
    Thanks for the inputs. Did you have any specific information about the problem with the Windows Agent ?
    Thanks
    Bye
  • 4.  RE: Automation Engine v12.3.9 HF1 removed from downloads site
    Posted 11 days ago
    Hi @Michael Lowry,
    thanks for the warning. I've installed this version some weeks ago in our test environment. So far we didn't have issues with the windows agent, but I wouldn't go to production with this release after you warning. Would be glad if someone could give details on the error.
    ​Regards, Matthias
  • 5.  RE: Automation Engine v12.3.9 HF1 removed from downloads site
    Posted 11 days ago
    Hi Michael,
    thank you for the information!
    We already deployed that version on some of our systems.
    So far, we did not observe any issues with the Windows agent 12.3.9 HF1.
    @Broadcom Support:
    Do you have more details about the problem with the Windows agent? Is the Windows agent affected or the AE?
    We need that information in order to keep an eye on potentially affected agents.
    Also, we probably have to decide whether to rollback the Windows agent to 12.3.9.
    Kind regards
    Norbert
  • 6.  RE: Automation Engine v12.3.9 HF1 removed from downloads site
    Posted 10 days ago
    Automation Engine v12.3.9 HF1 is back on the downloads site.
    As far as I can tell, the build numbers are the same as last week. I was not able to find an announcement of what if anything was changed.
  • 7.  RE: Automation Engine v12.3.9 HF1 removed from downloads site
    Broadcom Employee
    Posted 9 days ago
    We pulled 12.3.9 HF1 from our download center. as we discovered an escaped defect in 3 of our agent components. We have re-published 12.3.9 HF1 without following components: Windows Agent, AS/400 Agent, z/OS agent.
    Once we have addressed the issues in the affected agents, we will publish 12.3.9 HF1 once again. At this time I cannot provide a date as to when we will re-publish 12.3.9 HF1.
    Kaj Wierda
    Sr. Product Line Manager | Automation
    Broadcom Software
  • 8.  RE: Automation Engine v12.3.9 HF1 removed from downloads site
    Posted 9 days ago
    Hello Kaj,
    could you please provide more information about the "escaped defect"?
    We still need to decide whether to asap rollback our Windows agents to 12.3.9 or to wait for a 12.3.9 hf2 fix.
    - What is the impact of the issue? Job aborts? Agent crash? Security leak?
    - In which cases does the issue occur? What is needed to reprocude the issue?
    - What do you suggest to users with already installed Windows agents 12.3.9 hf1?
    As said, the Windows agent 12.3.9 hf1 seems to be stable so far.
    Even more surprising, why Broadcom decided to do this unexpected step and revoke the agent.
    Kind regards
    Norbert
  • 9.  RE: Automation Engine v12.3.9 HF1 removed from downloads site
    Posted 9 days ago
    Hello
    I opened a case to receive more information about Broadcom about this problem. There is a KB article with all information
  • 10.  RE: Automation Engine v12.3.9 HF1 removed from downloads site
    Broadcom Employee
    Posted 9 days ago
    Some additional details about escaped defect:
    1)
    we discovered that changes meant for 12.3.9 HF2, the hotfix that will address CVE-2022-33756, somehow made it into 12.3.9 HF1. So an escaped fix, rather than an escaped defect. These changes lead to AS/400 agents and z/OS failing to connect to AE at startup.
    2)
    As already pointed out by Donata Fagella, there is a KB article that explains the issue for Windows agents related to file transfer.
    If you are not experiencing 1) or 2) then no action is required until we re-issue 12.3.9 HF1
    Kaj Wierda
    Broadcom Software
  • 11.  RE: Automation Engine v12.3.9 HF1 removed from downloads site
    Posted 9 days ago
    Edited by Michael Lowry 9 days ago
    Thanks for this information.
    In future, we would appreciate a more timely announcement when download files are withdrawn, so that we can better judge the risk of installing or continuing to use the affected components.
  • 12.  RE: Automation Engine v12.3.9 HF1 removed from downloads site
    Posted 6 days ago
    Automation Engine v12.3.9 HF1 was briefly unavailable again this morning, but now it appears in the list again.
    The Windows agent is available. The AS/400 agent is not available despite being listed in the CSV file.
