VMware NSX
 AVI Load Balancer 22.1.7 VIP Creation: Error 400 on POST /api/vsvip
left_right's profile image
left_right posted Dec 09, 2024 08:09 AM
I'm pulling my hair out because of the following problem.
I need to deploy a VIP automatically, using a Python script. It is basically only a POST against the /api/vsvip API, by using the Python requests module.
I have previously created some other objects this way without issues, like a Cloud or Pool.
The problem I am facing now is, that every time I use POST to create a VIP, I get an error 400 as response with the message: "error": "VrfContext not found"
However, when I take the payload and copy it into the Swagger UI and POST it there, it works fine. The same user account is used. The VRF Context is passed as a "vrf_context_ref" attribute in the payload and is 100% correct.
Another test I did was to create a VIP using the Controller UI, capture the payload using the browsers' developer mode and use this payload as a variable value for the payload in the Python script. With this, I also get the same error as above.
Here is the payload I used for testing:
  "east_west_placement": false,
  "cloud_ref": "https://controller_url/api/cloud/cloud-2d7450ed-aa93-45d4-ada9-0fc2496f5d41#cloud_name",
  "dns_info": [
      "type": "DNS_RECORD_A",
      "algorithm": "DNS_RECORD_RESPONSE_CONSISTENT_HASH",
      "fqdn": "vip1.mydomain.local"
  "vip": [
      "enabled": true,
      "auto_allocate_ip": true,
      "auto_allocate_floating_ip": false,
      "avi_allocated_vip": false,
      "avi_allocated_fip": false,
      "auto_allocate_ip_type": "V4_ONLY",
      "prefix_length": 32,
      "ipam_network_subnet": {
        "network_ref": "network_ref_from_ipam",
        "subnet": {
          "ip_addr": {
            "addr": "10.1.1.0",
            "type": "V4"
          "mask": 27
      "vip_id": 1
  "bgp_peer_labels": [],
  "vrf_context_ref": "https://controller_url/api/vrfcontext/vrfcontext-d20b9c13-ebd5-4e78-8b05-b215add157d9#T1-Gateway",
  "tier1_lr": "/infra/tier-1s/T1-Gateway",
  "name": "manualviptest"
Request URL: https://controller_url/api/vsvip
Is it a bug maybe?
I am out of ideas.
Sulaiman Lodewyk's profile image
Sulaiman Lodewyk
Have you tried to submit the request with only using "vrf_context_ref": "api/vrfcontext/vrfcontext-d20b9c13-ebd5-4e78-8b05-b215add157d9#T1-Gateway"
left_right
Solved, turned out to be a Layer8 problem...
