VMware NSX
Expand all | Collapse all
upgrade edge node manually
  • 1.  upgrade edge node manually
    Posted Aug 07, 2021 05:39 PM
    Hi,
    How can you upgrade edge node manually?
  • 2.  RE: upgrade edge node manually
    Posted Aug 11, 2021 04:10 PM
    my two cents are:  that is not recommended, the reason the upgrade is part of an automated process (ESXi hosts, nsxmgrmg, edges, etc.), and sequence should be care, also is recommended to have mode than one EDGE VM.
    check this for more info in formal way: https://docs.vmware.com/en/VMware-NSX-T-Data-Center/3.0/nsxt_30_upgrade.pdf
