VMware NSX
  • 1.  Resetting root and admin passwords problem
    Posted Jul 25, 2024 05:08 AM
    Hello
    NSX-T v 3.0.2.0.0.16887200 in a 3 node cluster, within a VCF 4.4.0 environment.
    One of the config drift bundles for the SDDC manager is failing to install due to a credential issue with NSX.
    The issue appears to be that the root and admin passwords are reverting to a previous value.
    I have reset both passwords on all three nodes multiple times, however within a few seconds they are reverting to the previous passwords which does not match the password held in the SDDC manager.
    It seems that there is some background sync task that is updating the passwords whenever I reset them.
    Trying to update or remediate the password from the SDDC manager side fails.
    Any ideas please?
    Thanks
  • 2.  RE: Resetting root and admin passwords problem
    Posted Jul 26, 2024 07:15 AM
    What command did you use to change the password? From what I have seen others post, using passwd tends to change the password, but it later reverts. However, the correct command is:
    set user admin password YourNewPassword
  • 3.  RE: Resetting root and admin passwords problem
    Broadcom Employee
    Posted Jul 27, 2024 01:23 AM
    Hello JMW83,
    YOu can first reset the passwords of the admin and root users on the NSX-T appliances following this VMware official documentation: https://docs.vmware.com/en/VMware-NSX-T-Data-Center/3.2/administration/GUID-8816B842-2EC4-40A8-A618-F68DB29FABD2.html.
    After this please use the update option within VCF SDDC manager to update the passwords of the NSX-T appliances into the SDDC database, and this should get successfully synced. These steps should resolve your issues.
    THanks and Regards
    Sriram
  • 4.  RE: Resetting root and admin passwords problem
    Broadcom Employee
    Posted Jul 27, 2024 01:28 AM
    For any other credentials issues in SDDC manager related to NSX components you can also refer to this public kb article for reference: https://knowledge.broadcom.com/external/article/314657/credential-operations-fail-on-nsx-compon.html
    Regards
    Sriram
