VMware NSX
  • 1.  NSX-T Federation and AVI Advance Load Balancer
    Posted Jan 06, 2023 02:11 PM
    I am having trouble implementing AVI Advance Load balancer with NSX-T Federation.
    The problem is that I cannot select the overlay segment for management and data networks:
    br,
    GG
  • 2.  RE: NSX-T Federation and AVI Advance Load Balancer
    Posted Jan 06, 2023 05:58 PM
    That is unfortunately expected behavior. When using the NSX-T integration, you can only select local manager objects. You cannot select objects created at the GM level and pushed to the LMs.
  • 3.  RE: NSX-T Federation and AVI Advance Load Balancer
    Posted Jan 09, 2023 07:56 AM
    And then how can I implement NSX ALB since I only have GM objects? Any Idea?
  • 4.  RE: NSX-T Federation and AVI Advance Load Balancer
    Posted Jan 09, 2023 06:26 PM
    You have two options:
    1. Create LM objects and use those with the NSX-T integration.
    2. Don't use the NSX-T integration and manage the SEs/networks/etc. by hand.
  • 5.  RE: NSX-T Federation and AVI Advance Load Balancer
    Posted Jan 17, 2023 12:37 PM
    Tnx for your information.
    If we dont use the NSX-T Integration, we need additional License for AVI LB or can we use the license from NSX-T?
  • 6.  RE: NSX-T Federation and AVI Advance Load Balancer
    Posted Jan 17, 2023 11:56 PM
    You can still use the NSX-T license without using the NSX-T integration. You just enter the license in the NSX ALB (AVI) interface.
  • 7.  RE: NSX-T Federation and AVI Advance Load Balancer
    Broadcom Employee
    Posted Jan 20, 2023 12:32 PM
    Just to add on top of  words - you will receive Basic license tier with NSX-T key with multiple limitations in place. More on https://avinetworks.com/docs/22.1/nsx-alb-basic-edition/#feature-comparison-datasheets
    At the very beginning you will have just 2 clouds mode - without Orchestrator or NSX cloud connector.
    HTH,
    Dragan
