Hi ,
thanks for your reply...
I am not very familiar with the functionality of the fault domain, so I try to explain what I understand.
I install and configure 3 node NSX-T Manager.
I create 2 Edge for each site and then create an Edge Cluster with all Edges.
I create a T0-Gw (Act/Act) with 8 Uplinks (two for each Edge), enable ECMP and configure Route Maps for correct routing in case of site failure.
I create one T1-Gw (Act/Stb) for each site (with Only DR or also SR ?)
For each Edge, I configure Failure Domain (Edge1 and Edge2 in Failure Domain-A ;Edge3 and Edge4 in Failure Domain-B), in this way T1-A Std will position on the Edge of Site-B and T1-B Std on those of Site-A, right?
Now, I've some questions...
Is it possible to create 2 NSX-T Manager nodes in Site A and 1 in Site B if the hosts are in two different clusters? (This way I can avoid restoring NSX-T in the event of a site failure)
Does T0-Gw use Failure Domain function like T1-Gw when I implement it in Act / Act mode? If, NO ... how will the T1 traffic be forwarded to the edge if the T0 is not present in the event of a site fault?
Sorry and Thanks again...
