The Host TEP which is currently using VLAN 0 is working properly (communication between esxi and VMs work as designed), but for the Edge TEP using VLAN 70 it doesn't work. As per the Vmware documentation we don't require to create a dedicated port group for edges (As I have seen in many tutorials), the physical port is in Access 70.
To troubleshoot, we created two VMs and assigned them IPs similar to the edges and VLAN 70 and they can communicate. So it's definitely something to do with the edge configuration which does not allow external communication.
Any idea on what can be causing the issue ?
Attached are the screenshot for deploying the Edge.
Thank you
