VMware NSX
Expand all | Collapse all
monitor nsx edge process and service
  • 1.  monitor nsx edge process and service
    Posted Jun 15, 2017 02:47 AM
    Any one know how to monitor nsx edge process and service?
  • 2.  RE: monitor nsx edge process and service
    Broadcom Employee
    Posted Jun 15, 2017 05:06 AM
    Hi,
    NSX Manager Central CLI has the feature to monitor Edge.
    For example, the following commands are useful.
    This CLI can be executed by using REST API.
    * Command sets
    NSXM> show edge
      all            Show all Edge Service Gateway Appliances
      EDGE-ID        Show Edge Service Gateway Information
      EDGE-ID.HA-ID  Show Edge Service Gateway Information with appliance
    NSXM> show edge edge-7
      <cr>
      version        Show version
      eventmgr       Show event manager statistics
      log            Show system logs
      ipset          Show ipset information
      nat            Show nat packet counters
      arp            Show arp cache
      firewall       Show firewall packet counters
      flowtable      Show flow table
      process        Edge Process Commands
      system         Edge System Commands
      messagebus     Edge Messagebus Commands
      configuration  Edge Configuration Commands
      interface      Edge Interface Command
      ip             Edge IP Commands
      service        Edge Service Commands
    * Edge Summary
    NSXM> show edge edge-7 (example)
    Type                     :gatewayServices
    1)
    Host                     :esxi-03.vapp.local
    Deploy Status            :true
    -----Services Configuration Status-----
    L2VPN                    :false
    Firewall                 :true
    DNS                      :true
    SSLVPN                   :true
    Routing                  :true
    HA                       :false
    Syslog                   :true
    Load Balancer            :true
    GSLB                     :false
    IPSEC                    :false
    DHCP                     :false
    NAT                      :true
    Bridges                  :false
    * Edge process list (example)
    NSXM> show edge edge-7 process list
    haIndex:              0
    %CPU %MEM    VSZ   RSZ STAT  STARTED     TIME COMMAND
    0.0  0.1   4244   728 Ss     Apr 28 00:01:08 init [3]
    0.0  0.0      0     0 S      Apr 28 00:00:00 [kthreadd]
    0.0  0.0      0     0 S      Apr 28 00:19:59 [ksoftirqd/0]
    0.0  0.0      0     0 S<     Apr 28 00:00:00 [kworker/0:0H]
    0.0  0.0      0     0 S      Apr 28 00:15:41 [rcu_sched]
    Regards,
    Mizo.
