hi,
Please find the details on interfaces in this article.
NSX – Distributed Logical Router Deep Dive – VMware Professional Services
Uplink: This is used by the DLR Control VM to connect the upstream router. In most of the documentation you will see, it is also referred to as “transit”, and this interface is the transit interface between the logical space to the physical space. The DLR supports both OSPF and BGP on its Uplink Interface, but cannot run both at the same time. OSPF can be enabled only on single Uplink Interface.
LIFs: LIFs exist on the ESXi host at the kernel level; LIFs are the Layer 3 interface that act as the default gateway for all VM’s connected to logical switches.
Management: DLR management interface can be used for different purposes. The first one is to manage the DLR control VM remote access like SSH. Another use case is for High Availability. The last one is to send out syslog information to a syslog server. The management interface is part of the routing table of the control VM; there is no separate routing table. When we configure an IP address for the management interface only devices on the same subnet as the Management subnet will be able to reach the DLR Control VM management IP, and the remote device will not be able to contact this IP.
