Hi all
I would like to connect several T1 routers to a single hub segment. These T1 routers would not be attached to an Edge cluster because they would not require any SR. The intended topology would look like as follows:
------------------------------- Segment Hub
T1a T1b T1c
Segment A Segment B Segment C
In the above example, there is only a single segment "below" each T1, but the intention would be to have several segments.
So far I haven't found how to achieve this.
Many thanks in advance
