VMware NSX
  • 1.  About NSX Edge load balancer Weight
    Posted Apr 24, 2018 05:31 AM
    Hello.
    Weight is set in Pool of load balancer
    Please tell me what action will be taken if Weight is set.
    I confirmed the operation
    We had a movement that was frequently allocated to servers with high Weight numbers
    Is this movement correct?
    I'd like to do traffic forwarding to the intended server.
    (BIG-IP - Priority Group Activation) operation
    For example
    · There are four web servers (web1, web2, web3, web4).
    - When normal, only load 1 is set for web 1 and web 2.
    · When web 1 fails, only web2 communication
    - When web1 and web2 fail, they communicate with web3 and web4.
    To do this
    Weight setting below.
    web1 weight1
    web2 weight1
    web3 weight2
    web4 weight2
    Argorithm: Round-Robin
    But the operation
    Communication is possible in all situations.
  • 2.  RE: About NSX Edge load balancer Weight
    Best Answer
    Broadcom Employee
    Posted Apr 24, 2018 01:45 PM
    The "weight" parameter is just a way of setting a proportion of the traffic that will be delivered to a given pool member so regardless of what you do, all servers in a given pool will always receive some traffic (some just receive more than others and higher weight receives more traffic so the way you've got it configured now, web 3/4 will receive twice as much as web 1/2).
    Just to make sure I understand, it sounds like what you're after is to have web 1 and web 2 receive all the traffic unless both are down, and only then start sending traffic to web 3 and web 4.  If that's the case, you'll need to put web 1 and 2 in their own pool (let's call that 'active_pool' for the sake of this example) and web 3 and web 4 in a separate pool ('standby_pool' for example) and use an application rule to fail over to the 'standby_pool' when both servers in the 'active_pool' are down.  To do so, you can set the default pool on your virtual server to the 'active_pool' and then apply the following application rule:
    acl active_down nbsrv(active_pool) eq 0
    use_backend standby_pool if active_down
  • 3.  RE: About NSX Edge load balancer Weight
    Posted Apr 24, 2018 11:50 PM
    lhoffer>
    Thanks for your comment.
    understood.
  • 4.  RE: About NSX Edge load balancer Weight
    Posted Apr 24, 2018 08:13 PM
    Hello, I wrote a blog post on that here: Creating an Active-Passive Pool on VMware NSX Load Balancer
  • 5.  RE: About NSX Edge load balancer Weight
    Posted Apr 24, 2018 11:52 PM
    Bayu Wibowo>​
    I will look at the blog.
