Automic Workload Automation
  • 1.  Return code in post process script
    Posted Sep 30, 2022 01:02 AM
    HI Everyone
    sub_xyz failed with below error message
        "detailedMessage": "",
    Job failed
    **  TEXT="        Job ended               "       RETCODE=01
    Above is the log of a failed job that throws return code as 1 .User wants return code 1 to make the job ended ok in UC4.What is the post process script to be used in job to make the return code status 1 as successfull.
  • 2.  RE: Return code in post process script
    Posted Sep 30, 2022 04:38 AM
    Hi Mani,
    apart from AE script and the use of an Output filter you can change the max. value for the Runtime tab of the jobs:
    regards,
    Peter
    Automic Certified Professional & Expert & Knight
    For AUTOMIC trainings please check https://www.qskills.de/qs/workshops/automic/
