Hi Peter,
Thanks for the reply. i think i figured out it still some testing i need to do, i am using below code in call mail to achieve this
:SET &RunID = GET_UC_OBJECT_NR(&uc_slm_service_name#)
:SET &parent# = GET_PARENT_TYPE(&RunID, ACT)
:If &parent# = "USER"
: PRINT &parent#
: PRINT 'Its Adhoc submission skipping notifications'
: STOP NOMSG
:else
: PRINT &parent#
Original Message:
Sent: Mar 29, 2023 10:24 AM
Subject: Is it possible to send notification using SLO object only for job running through schedule and not for adhoc submission
Hi Arun,
in your jobs get the result of SYS_ACT_PARENT_TYPE using :PSET. In the CALL object use the script variable and check if the type is JSCH -> send the notification.
https://docs.automic.com/documentation/webhelp/english/ALL/components/DOCU/21.0.5/Automic%20Automation%20Guides/Content/Script/Reference/SYS_ACT_PARENT_TYPE.htm?tocpath=Reference%7CAutomation%20Engine%20Script%20Reference%7CScript%20Elements%20Ordered%20by%20Purpose%7CWorkflows%7C_____10
regards,
Peter
Automic Certified Professional/Expert & Broadcom Knight
For AUTOMIC trainings please check https://www.qskills.de/qs/workshops/automic/
Original Message:
Sent: Mar 29, 2023 02:20 AM
Is it possible to send notification using SLO object only for job running through schedule and not for adhoc submission , if yes how?
