VMware {code}
 Reproducible VMDirectPath I/O failure with populated xHCI USB controllers – IOMMU/DMAR fault during VM power-on
Igor Bornay's profile image
Igor Bornay posted Aug 01, 2026 02:24 PM
Hello Broadcom / VMware Engineering,
I would like to report a reproducible VMDirectPath I/O issue involving PCI passthrough of an entire USB xHCI controller.
ENVIRONMENT
Host:
- Dell PowerEdge T360
- Intel Xeon E-2488
- VMware ESXi 8.0 Update 3e
Guest:
- Windows Server 2025
Primary USB controller:
- Intel Raptor Lake USB 3.2 Gen 2x2 xHCI Host Controller
- PCI address: 0000:00:14.0
- Vendor / Device ID: 8086:7a60
ESXi reports for this device:
Configured Owner: VM Passthru
Current Owner: VM Passthru
Passthru Capable: true
Reset Method: Power state reset
FPT Sharable: true
The passthru.map configuration contains:
8086  7a60  d3d0  false
PROBLEM
PCI passthrough of the complete xHCI controller is reproducibly affected by whether USB devices are attached to the controller before the virtual machine is powered on.
When affected USB ports are empty, VMDirectPath assignment succeeds and the Windows Server 2025 VM starts normally.
When a USB peripheral is attached to an affected port before VM power-on, VMDirectPath initialization can fail and the VM does not start.
FAILURE SIGNATURE
During a failed VM power-on, vmkernel.log shows the xHCI passthrough device being allocated, followed by an Intel VT-d / IOMMU / DMAR fault involving the same device:
PCIPassthru: pcipDevInfo allocated for 0000:00:14.0
WARNING: VTD IOMMU Fault ... Device 0000:00:14.0 Addr = 0x40000000000
WARNING: DMAR Fault ... Device 0000:00:14.0 Addr = 0x40000000000
IOMMU Fault detected. IOaddr 0x40000000000
ESXi subsequently removes the passthrough binding/domain and VM power-on fails.
REPRODUCIBLE BEHAVIOR
Working case:
1. Boot ESXi.
2. Keep the affected USB ports empty.
3. Power on the VM with 0000:00:14.0 assigned by VMDirectPath I/O.
4. Passthrough succeeds and the VM starts.
Failing case:
1. Boot ESXi.
2. Attach a USB peripheral to an affected USB port before VM power-on.
3. Power on the same VM with the same passthrough configuration.
4. The passthrough handoff fails and an IOMMU/DMAR fault is logged.
IMPORTANT TOPOLOGY OBSERVATION
The behavior depends on USB topology.
On this Dell PowerEdge T360, USB devices connected through the three rear SuperSpeed ports located behind the onboard USB hub topology can remain attached during VM power-on and the xHCI passthrough succeeds.
USB devices attached to certain other/direct USB ports can cause the passthrough power-on failure.
Placing an external USB hub on an affected direct port does not solve the problem. If a USB device is present behind that external hub during VM power-on, passthrough can still fail.
ESXi can enumerate and use USB devices connected through the working rear SuperSpeed ports before the controller is passed through. Therefore, the issue does not appear to be simply that ESXi must never enumerate a USB device before passthrough.
SECOND CONTROLLER OBSERVATION
A similar behavior was observed with a separate PCIe USB controller:
- PCIe USB controller with no USB device attached at VM power-on -> passthrough succeeds.
- Same PCIe USB controller with a USB device attached at VM power-on -> passthrough fails.
This suggests that the problem may be related to reset, DMA/IOMMU state, or handoff of an active/populated xHCI controller rather than to one specific physical USB connector on the motherboard.
RESET INFORMATION
For Intel 8086:7a60, ESXi reports:
The passthru.map entry explicitly uses:
d3d0
The PCI capability list of this integrated xHCI function does not advertise a standard PCI Express Function Level Reset capability, so the controller is being handed over using a power-state reset rather than FLR.
EXPECTED BEHAVIOR
A PCI device reported by ESXi as passthrough-capable should be safely reset and assigned to the VM regardless of whether USB endpoints are already attached, or ESXi should document this limitation if populated xHCI controllers are unsupported during VMDirectPath handoff.
ACTUAL BEHAVIOR
With certain USB devices/ports active before VM power-on, the xHCI controller produces an IOMMU/DMAR fault during VMDirectPath initialization and the VM fails to power on.
CURRENT WORKAROUND
All permanently connected USB peripherals are kept on the three rear SuperSpeed ports whose onboard hub topology does not trigger the problem.
Other affected USB ports must remain empty during VM power-on.
REQUEST
Please confirm whether this is a known VMDirectPath/xHCI reset or IOMMU issue.
If known, please advise:
- whether it is fixed in a later ESXi 8.x build,
- whether there is an official VMware/Broadcom workaround,
- and whether there are any recommended reset or passthrough settings for populated xHCI controllers.
I can provide full vmkernel logs, PCI configuration-space dumps, esxcli hardware pci output, and USB topology information if required.
Best regards,
Igor Bornay
GynVi s.r.o.
