vSAN1
Expand all | Collapse all
Why vmkping for vsan does not work after enabled flow offload on network device configuration in system bios
  • 1.  Why vmkping for vsan does not work after enabled flow offload on network device configuration in system bios
    Posted Aug 30, 2026 07:49 AM
    Please find attached pic about flow offload . I want to now . Does it recommend to enable while using vSAN ?
    While it is enabled my vmotion and vsan traffic between vmkernels does not work and cannot vmkping each others but when disabled it vmkping work for both vMotion and vSAN traffic . what is the issue  ?
  • 2.  RE: Why vmkping for vsan does not work after enabled flow offload on network device configuration in system bios
    Best Answer
    Posted Sep 01, 2026 04:27 PM
    Edited by Bab Sep 02, 2026 02:23 AM
    It is strictly recommended to keep this setting "Disabled" for vSAN and vMotion traffic. The issue is a compatibility and driver design mismatch between the physical NIC's hardware forwarding engine and the VMware ESXi operating system.
    The "Flow Offload" feature (powered by Broadcom's TruFlow engine) is designed to accelerate networking by pushing routing and switching flow tables down to the physical NIC hardware. However, this feature is only supported on Linux operating systems (specifically for Open vSwitch / OVS or DPDK packet processing). VMware ESXi does not support this specific hardware offloading mechanism for standard VMkernel adapters.
    When you set Flow Offload to "Enabled" in the BIOS:
    • The Broadcom NIC changes its packet-forwarding pipeline, expecting the operating system driver to program hardware-level flow tables with instructions on where to send traffic.
    • Because VMware ESXi's native driver (bnxtnet) does not use this Linux-specific feature, it never programs the flow tables on the NIC hardware.
    • As a result, when packets (like basic vmkping ICMP requests, vMotion TCP streams, and vSAN cluster communications) hit the physical NIC, the hardware has no flow rules mapped for them.
    • The NIC silently drops the packets directly at the hardware layer before they can reach the ESXi network stack or exit the host, creating a "black hole" for your VMkernel traffic.
    Disabling it reverts the NIC to standard Layer 2/Layer 3 frame forwarding, which perfectly aligns with how ESXi standard and distributed vSwitches operate.
    Reference URLs backing these details:
    1. Broadcom TechDocs - UEFI HII Menu Configuration:
    2. Broadcom TechDocs - OVS and DPDK Flow Offloads:
    If you find this answer right, please 'Recommend' this post.
    Thank you!
    Regards,
    Shen
