ESXi
Expand all | Collapse all
Why ESXi do not create same NFS ID as ESX for same Datastore ?
  • 1.  Why ESXi do not create same NFS ID as ESX for same Datastore ?
    Posted Oct 05, 2010 07:48 AM
    Hello,
    In my environment I have both ESX and ESXi (4.0 U2) connected to vCenter (4.1)
    I found something strange in my environment which result in a failure to load VMs.
    When I create an NFS datastore in ESX, it creates in /vmfs/volumes a link to this datastore with an ID (ie : fabc42ce-b4aa5fac)
    When I create an NFS datastore in ESXi, it creates in /vmfs/volumes a link to this datastore with another ID (ie : 45c02564-e2adc9c4)
    but in both cases, alias (name of datastore) is identical.
    I also use Lab Manager which use linked clone and refer some parent path to VM, but when I deploy from ESX or ESXi, I cannot deploy it and have an error (Requested file "" not found.) because ESX or ESXi refer to different datastore IDs.
    Is there a way to get same Ids for the same datastore created in either ESX or ESXi ? aliases (are the same, but IDs are differents)
    Regards
    Divi
  • 2.  RE: Why ESXi do not create same NFS ID as ESX for same Datastore ?
    Posted Oct 05, 2010 10:10 AM
    Found, thanks to VMware support :smileyhappy:
    in fact in ESX datastore where mapped using IP address and in ESXi datastore was created with FQDN.
    in ESX/ESXi use "esxcfg-nas -l" command to found out how they were created.
    Divi
  • 3.  RE: Why ESXi do not create same NFS ID as ESX for same Datastore ?
    Posted Oct 05, 2010 10:24 AM
