vCenter
Expand all | Collapse all
VMotion problem - 'device with remote backing'
  • 1.  VMotion problem - 'device with remote backing'
    Posted Jan 17, 2007 09:43 AM
    When trying to VMotion from one ESX server to another, I receive this error:
    Unable to migrate from ESX1 to ESX2: Virtual machine is configured to use a device that prevents migration: Device 'CD/DVD Drive 1' is a connected device with a remote backing.
    If i view the virtual machine properties, the CD/DVD drive is showing as 'Connected - client unknown'. All of the CD/DVD properties are greyed out.
    I can click the 'Disconnect D:' button on the toolbar with the VI client, but this doesnt have any effect.
    Any ideas?!
    P.S i even tried removing the CD/DVD device whilst the VM was powered off, powering up the VM, powering it down, and re adding the CD/DVD but this didnt have any effect.
    Thanks
  • 2.  RE: VMotion problem - 'device with remote backing'
    Posted Jan 19, 2007 01:59 PM
    You should find what is configured to use the device.
    Another way: did you try unistalling the device in the virtual OS?
  • 3.  RE: VMotion problem - 'device with remote backing'
    Posted Jan 19, 2007 02:17 PM
    I have this same issuse on a VM i use for testing VMotion, its been used 100's of times for VMotion..
    Removing the CD/DVD didnt help, but removing both the CD/DVD and Floppy did the trick..
    I havent looked too deeply into it.. But will do later..
  • 4.  RE: VMotion problem - 'device with remote backing'
    Posted Jan 19, 2007 11:09 PM
    I think that is caused by a vcenter user with the console open to the VM that has the CD connected via Device type "Client Device"
    Check the sessions on the server and see if anyone has that vm open.
  • 5.  RE: VMotion problem - 'device with remote backing'
    Posted Jan 20, 2007 12:49 AM
    I added my CD/DVD and floppy back, but still get the issues.. But that a good shout, as that VM has had console connected via VC, although all have been closed and VM rebooted etc..
  • 6.  RE: VMotion problem - 'device with remote backing'
    Posted Jan 20, 2007 03:28 AM
    That's really curious. If you can shutdown the vm for a few minutes, try making a new VM pointing to the existing disk files and see if that will vmotion.
  • 7.  RE: VMotion problem - 'device with remote backing'
    Posted Jan 20, 2007 04:33 PM
    Im quite sure that would work, i'll see if i can get chance to test..
  • 8.  RE: VMotion problem - 'device with remote backing'
    Posted Jan 26, 2007 11:11 AM
    Couldn't work out what was causing this...there weren't any sessions showing.
    I removed the VM from virtual center, and then re-registered it. This did the trick - can now VMotion OK.
    thanks for the suggestions.
  • 9.  RE: VMotion problem - 'device with remote backing'
    Posted Jan 26, 2007 03:43 PM
    Glad to hear that helped.
    Thanks for the points!
  • 10.  RE: VMotion problem - 'device with remote backing'
    Posted Feb 20, 2007 12:15 PM
    I'm still having these problems, but now it's happening on 9 of our VMs - a real pain. Only way I can see to fix is to remove the VMs from virtual centre and reregister them.
    Just wondering if anyone else has any ideas?
    James
    Message was edited by:
    jparnell
  • 11.  RE: VMotion problem - 'device with remote backing'
    Posted Apr 10, 2007 01:10 AM
    I've had the same problems on my VMs running linux OS-es.
    And NOW I resolve the problems!! Yeah!!
    The cause is that my VMs hold "VMware Tools Install" images on their Virtual CD-ROM drives.
    Click "Inventry->Virtual Machine->End VMware Tools Install".
    It may save you.
  • 12.  RE: VMotion problem - 'device with remote backing'
    Posted Apr 10, 2007 12:49 PM
    I have seen this too. If the VM tools install thinks it is still running the CD drive is mapped to the iso file on the host. You wont be able to VMotion until you disable the tools install.
  • 13.  RE: VMotion problem - 'device with remote backing'
    Posted Apr 11, 2007 04:07 PM
    I had the same problem and found this solution in another post:
    When trying to vmotion a virtual machine you may get an error message that says you cannot migrate the vm because the CD is connected to a device that prevents migration. If you try to disconnect that device it may stay connected. If it does, open an SSH connection to the ESX host.
    Once connected run the following command: "service mgmt-vmware restart"
    This will restart the management interface and should clear the connection to the CD or floppy.
    Bill S.
  • 14.  RE: VMotion problem - 'device with remote backing'
    Posted May 03, 2007 09:30 PM
    I couldn't select to end my instlal but doing a "repair" fixed my remote backing issue.
    Ben
  • 15.  RE: VMotion problem - 'device with remote backing'
    Posted May 18, 2007 03:38 AM
    Had another one today, I did a 'mgmt-vmware restart' and it fixed the problem.
  • 16.  RE: VMotion problem - 'device with remote backing'
    Posted Jan 08, 2009 03:20 PM
    Thanks, this worked for me
  • 17.  RE: VMotion problem - 'device with remote backing'
    Posted Apr 06, 2011 05:46 PM
    Same issue, same situation, slightly different fix.
    Linux OS, same situation - CD/DCD set to client device with greyed out options, cannot vMotion.
    The VMware Tools ISO was no longer mounted, but it was related to VMware Tools installation.  I had recently performed a successful tools install, which completed and dismounted the ISO.
    However, it seems that the VM thought the ISO was still mounted.  In Linux, I tried to "umount" the cdrom, which did not help.
    I then started a new VM tools install, which mounted the ISO, waited until the mount was completed, then ended VM tools installation.
    This fixed the problem!
    Thanks guys, for your posts.
  • 18.  RE: VMotion problem - 'device with remote backing'
    Posted May 14, 2007 06:16 PM
    I have tried th uninstall and re-install of both the floppy and the CD-Rom although still no luck. What I did find to work more than once it powering down your VM > ensure either Floppy and or CD-Rom are both disconnected > Migrate to another ESX server > Power VM up > try to VMotion.
    I hope this helps
    JC
  • 19.  RE: VMotion problem - 'device with remote backing'
    Posted May 31, 2007 08:48 AM
    This should cure the problem without the need to shutdown the VM...
    Select "Install VMware Tools" on the Virtual Machine - this will initiate the VMware Tools Installer Mount.
    Select "End VMware Tools Install" - this will unmount the Tools Installer.
    A word of warning, the VMware Tools Installer Mount will forcibly disconnect the remote device, so if someone has genuinely mounted a Virtual CRDOM it will be lost.
  • 20.  RE: VMotion problem - 'device with remote backing'
    Posted Jun 20, 2007 09:22 AM
    Hi,
    I got a similar message during VMOTION. To resolve the issue, i did the following.
    1. Rihgtclick on the Virtual Machine and select 'Edit Settings'
    2. Select (Highlight) CD/DVD Drive 1
    3. On the right hand side under Device status, uncheck the box 'Connected'
    4. Try VMOTION (drag and drop the Virtual machine) and it should work.
    5. If required then check the box which was unchecked in step 3 (for the moved VM on the target server).
    Hope this helps!
    Regards,
    Ronald
  • 21.  RE: VMotion problem - 'device with remote backing'
    Posted Jun 21, 2007 02:20 PM
    In this scenario the CD/DVD Device Status shows up as "Connected - client unknown" and all of the properties are greyed out, so you can't Edit the Settings.
    I am not absolutely certain what the reason is for this behaviour, but I am able to recreate it...
    Connect a CD to a VM, then shutdown & power off; now remove the CD (i.e. set to "Client Device"), then power back on. Now try to VMotion and Hey Presto "Device 'CD/DVD Drive 1' is a connected device with a remote backing" and all options greyed out.
    The only certain workaround that I have found for this is to "Install VMware Tools"/"End VMware Tools Install", or even better disconnect the CD before shutting down the VM!
  • 22.  RE: VMotion problem - 'device with remote backing'
    Posted Jun 25, 2007 02:22 PM
    I've recently migrated a load of servers using vmware converter - and I have noticed we recieve the error on every server we migrate. I have got into the habbit of "install vmware tools"/"end vmware tools install"
  • 23.  RE: VMotion problem - 'device with remote backing'
    Posted Aug 15, 2007 01:42 PM
    One more addition. The previously posted solutions did not work for me but i found that my guests CDROM was configured to "Emulate IDE" under the Mode section in properties of the CDROM. I set it back to Passthough IDE and vmotion worked with properly.
    DG
  • 24.  RE: VMotion problem - 'device with remote backing'
    Posted Sep 07, 2007 07:39 PM
    Had this problem with one machine this morning.
    To fix it, I had to remove the cdrom AND floppy disk -> bootup so windows removed them from dev mgr -> shutdown and re-add them. (For good measure, you may consider deleting the hidden devices.)
    FWIW, the cd rom was originally set for "Emulate." Changing it to Passthrough did not[/i] work for me. I had to remove both devices.
  • 25.  RE: VMotion problem - 'device with remote backing'
    Posted Sep 14, 2007 03:11 PM
    I went into device manager and disabled the floppy drive and cd-rom. Once I did this I clicked edit settings and the cd-rom was no longer connected and I could migrate.
  • 26.  RE: VMotion problem - 'device with remote backing'
    Posted Sep 28, 2007 09:47 PM
    I simply reinstalled my VMWare Tools and it enabled me to VMotion correctly.
    Thanks,
    Josh
  • 27.  RE: VMotion problem - 'device with remote backing'
    Posted Dec 05, 2007 02:23 PM
    I had this issue on all my VMs since I had installed VMtools. I did a service mgmt-vmware restart on each ESX host 1 min later connected to unknown with the check box was gone...works like a charm.
  • 28.  RE: VMotion problem - 'device with remote backing'
    Posted Oct 23, 2009 07:41 AM
    this is help's me on vmware esx4 host.
    best regards, m0ps
  • 29.  RE: VMotion problem - 'device with remote backing'
    Posted Dec 03, 2010 02:58 PM
    Hi,
    I found a simple solution: login into VM via console and umount cdrom and after that eject it.
