ESXi
Expand all | Collapse all
VM have large capacity disc (More than 1T VMDK) can not Power ON
  • 1.  VM have large capacity disc (More than 1T VMDK) can not Power ON
    Posted Dec 22, 2016 01:20 AM
    some VM unable  Power on ,after Power off it.  Such VM  have large capacity disc (More than 1T VMDK) .
    Tips are as follows:
    VM is not actually doing any snapshot, the data is also normal, but is unable to boot. Have this kind of 1 t VMDK vm rotating one randomly appear
    Seemingly lock between a VM and storage LUN? There is no LCK files directly read data folder
    when power on  the virtual mechanical :
    Cannot open the disk
    '/vmfs/volumes/5666ab20-2d330265-22b9--
    842b2b585bc8/xxx.vmdk' or one of the snapshot disks it
    depends on.
    ESXI5 上总有几个VM 里面有1T的vmdk,关机 就无法打开电源。提示如下:
    实际上VM是没有做任何快照的,数据其实也都正常,但就是无法开机。  有这种1T VMDK的vm轮流着 随机出现
    貌似VM和 存储LUN之间有锁?  直接看数据文件夹是没有LCK文件的
  • 2.  RE: VM have large capacity disc (More than 1T VMDK) can not Power ON
    Posted Dec 23, 2016 12:59 PM
    by change the  value of MaxHeapSize
    I have solved this problem  .
