vCenter
  • 1.  Problem with VMware-Migration Assistant please help
    Posted Jun 21, 2018 01:01 PM
    Dear All
    I want to Migrate our Windows vCenter server 6.0U3  to vCSA 6.5
    When i trying to run VMware-Migration Assistant on Windows vCenter server, It's Failed
    I have this error
    Initializing Migration Assistant...
    Migration to VMware vCenter Server Appliance 6.5 is only supported from vCenter Server versions 5.5 and 6.0.
    No supported products were found on this machine.
    Shutting down Migration Assistant...
    Migration Assistant log file is located at: C:\Users\IT\AppData\Local\Temp\migration-assistant.log
    Failed to initialize Migration Assistant. Resolve the above error(s), and relaunch Migration Assistant.
    Press Enter key to exit.
    Anyone has an idea or had the same problem?
  • 2.  RE: Problem with VMware-Migration Assistant please help
    Posted Jun 21, 2018 01:28 PM
    What version of the 6.5 installer do you have there?
  • 3.  RE: Problem with VMware-Migration Assistant please help
    Posted Jun 22, 2018 02:08 PM
    I have VMware vCenter Server 6.5 U1
    VMware-VCSA-all-6.5.0-5973321
  • 4.  RE: Problem with VMware-Migration Assistant please help
    Posted Jun 21, 2018 07:13 PM
    A Migration from v6.0U3 to 6.5 requires v6.5U1, or later. See VMware Product Interoperability Matrices
    André
  • 5.  RE: Problem with VMware-Migration Assistant please help
    Posted Jun 22, 2018 02:14 PM
    it's support but with this notification (applies to vCenter server  as well as to update manager)
    So what this mean
  • 6.  RE: Problem with VMware-Migration Assistant please help
    Best Answer
    Posted Jun 22, 2018 04:41 PM
    Not sure why it doen't work in this case.
    Anyway, would it be an option for you to migrate to a later version of the vCSA (e.g. 6.5U1g - Build 8024368) rather than the one from July 2017 that you mentioned?
    Maybe it's an issue with the old Migration Assistant!?
    André
  • 7.  RE: Problem with VMware-Migration Assistant please help
    Posted Jun 22, 2018 08:13 PM
    Okay
    I will try tomorrow
