I don't know what you took as personal, but I seem to be more professional, because I knew stuff you didn't. But back to the topic at hand, you made a claim that VBS can't be disabled in Windows 11 Home, because you need GPEdit to do that. I said, "no you don't need GPEdit" and now I spent 2 hours installing a fresh Windows 11 24H2, enabling all Device Security features, making sure VBS is enabled, upgraded to Windows 11 25H2, installed VMWare Workstation 25H2, created a VM with CPU virtualization features enabled and verified that the VM can't boot because VBS hides the actual CPU virtualization features from Workstation. Then followed the instructions from the link I provided, rebooted twice to make sure VBS is not only disabled for one reboot and tested the same VM again. It booted fine. And to support my claim, here are two screenshots. My goal is to "remove" any misinformation, so if someone comes looking for solutions is not misled.
Original Message:
Sent: Jan 10, 2026 06:02 PM
Subject: Problem with running EVE-NG on VMware Workstation 25H2
I dont know why you becoming personal or act like more professional, I did all steps except step04
I just shared my experience how would i fix this issue under my circusmstances.
Broadcom employee shared same link as you do.
For me I am happy - I m utilizing my alienware laptop power by Intel Ultra core 9 for running Cisco SD-WAN, L2/L3, Firepower n junpiers images n also some time Call of duty BO7 😋
Original Message:
Sent: Jan 10, 2026 05:33 PM
LOL, you don't need GPEdit. You don't know that GPEdit is just a different way to edit the Registry, do you? The DG Readiness Tool, downloadable from Microsoft, can disable VBS, because it just edits a few keys in Registry to do it. The full step-by-step guide was posted already, which includes the DG readiness as an alternative way to GPEdit to disable Device Guard: https://community.broadcom.com/vmware-cloud-foundation/discussion/how-to-disable-hyper-v-in-windows-11-24h2 Just running a script does not make your computer an easy target, only if you download from dobious sources.
Original Message:
Sent: Jan 10, 2026 08:14 AM
LOL I dont need to spreading misinformation. I was suffering for last 2.5 months to fix this vmware app n windows os integration problems.
FYI : disable Virtualization-base Security can not be completelty disbabled in Windows11 home version. U need to do by both ways from registry n GPO. Even if u enable GPO in win11 home version still u wont find option device security, then you need batches files to disable VBS in windows 11 home- its makes ur pc/laptop easy meat for malware/Virus or windows malfunctions,.
Original Message:
Sent: Jan 10, 2026 03:40 AM
Stop spreading misinformation. The steps to disable Virtualization-base Security (aka VBS) has been documented on this forum already. Just search for it. You don't need Windows 11 Pro to do it.
Original Message:
Sent: Jan 05, 2026 10:16 AM
I got the solution.
You must upgrade your windows 11 Home license to Windows 11 Pro version
I upgraded to Windows 11 pro version and using VMware version :17.6.4 (VMware Workstation 17 Pro)
Then perform these below steps to use VMware nested virtualization for EVE simulator.
1) Disable Hyper-V via the GUI
Uncheck all Hyper-V related options.
2) CMD:
bcdedit /set hypervisorlaunchtype off
3) Using PowerCLI, remove all Hyper-V features:
Disable-WindowsOptionalFeature -Online -FeatureName Microsoft-Hyper-V-All
4) Restart
5) Disable Virtualization-Based Security (VBS):
Go to Windows Security > Device Security.
Under Core Isolation, turn Memory Integrity OFF
6) Restart
7) Open Windows Security -> Under Virus & threat protection, click Manage settings -> find Tamper Protection - > toggle it Off
8) Press Win + R, type gpedit.msc, and press Enter.
Navigate to Computer Configuration > Administrative Templates > System > Device Guard.
Double-click "Turn on Virtualization Based Security" and set it to Disabled.
Click Apply then OK
9) Restart your PC.
Nothing is free you have to pay for get the job done as I did for windows 11 pro license..!
Original Message:
Sent: Jan 04, 2026 07:24 PM
As I previously explained, VMware Workstation currently does not support nested virtualization currently when using WHP. If you need nested virtualization (and it sounds like EVE-NG does need it) , you will need to disable WHP and use the VMware hypervisor.
Original Message:
Sent: Jan 03, 2026 06:39 PM
Can you check my post I already shared all required logs. But still not get solution.
Is there any paid service to fix this issue ??
Original Message:
Sent: Dec 29, 2025 12:25 AM
As Dhairya has asked previously, please go to the VM Directory of the VM where you are seeing this error and check the latest vmware.log file.
Please confirm whether "vhv.enable" is present in the log. Also share the vmware log file
Original Message:
Sent: Dec 28, 2025 12:07 PM
hi i also blocked in here, everytime i configured it it just failed showing vcpu-0 vcpu-5 vcpu-2. is it not supported with my laptop, lenovo with ultra core 9 to use eve-ng and vmware?
