Automation
Problem with PowerCli in Multi-threading
  • 1.  Problem with PowerCli in Multi-threading
    Posted Jun 13, 2014 08:54 AM
    Hi,
    Sorry for my little English,
    I would like use PowerCli in Multi-threading, But my problem is at Data recovery. i haven't recovery all data of my variable when i execute my command
    For Example,
    if i execute the command "Get-cluster -Name "My_Cluser" | Get-View)"
    I recov the data to the root and root + 1, but it not shows me the rest
    i don't know how...
    if someone at a idea..
    Thank you
    and Sorry for my little English !!!
    My Code :
    $IPvCenter = "IP_VCENTER"
    Add-PSSnapin -Name "VMware.VimAutomation.Core" -ErrorAction SilentlyContinue
    Connect-VIServer $IPvCenter
    $SessionId= ($defaultviserver | select SessionId).sessionId
    $functions = {
          $Connect = Connect-VIServer $args[0] -Session $args[1]
          $ClusterInfo = (Get-cluster  -Name "My_Cluster" | Get-View) | select *
          return $ClusterInfo
    $Result = Start-Job -ScriptBlock $functions -argumentlist @($IPvCenter,$SessionId) | Wait-Job| Receive-Job
    # Example
         # Good
    $Result[1]
         # Bad
    $Result[1].ConfigurationEx
