VMware vSphere
  • 1.  Problem migrate PSC embedded to external PSC - Certificate problem SSL 6.5U1 - HELP!!!!!
    Posted Dec 05, 2017 01:10 PM
    HI
    I have a "VCENTER" which updates from 6.0U3 to 6.5U1, all right, now I need to outsource the PSC to a new one which is already connected to an SSO domain, I fulfill the requirement that it be the same domain "vsphere.local" and the same SITE, the problem is that it does not try to do anything since there is a problem with the certificate which I could not resolve.
    root@vcenter [ ~ ]# cmsso-util reconfigure --repoint-psc psc-01.example.com --username Administrator --domain-name vsphere.local --passwd "example"
    Validating Provided Configuration ...
    Falied to open connection https://psc01.example.com:443/websso/ Error: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:661)>
    Disign:
    Error when i try a openssl , in mi other vcenter i try the same and work fine
    root@vcenter [ /usr/lib/vmware-vmafd/bin ]# openssl s_client -connect psc-01.example.com:443
    CONNECTED(00000003)
    depth=0 CN = psc-01.example.com, C = US
    verify error:num=20:unable to get local issuer certificate
    verify return:1
    verify error:num=21:unable to verify the first certificate
    verify return:1
    Certificate chain
    0 s:/CN=psc-01.example.com/C=US
       i:/CN=CA/DC=vsphere/DC=local/C=US/ST=California/O=psc-01.example.com/OU=VMware Engineering
    Server certificate
    -----BEGIN CERTIFICATE-----
    MIID2TCCAsGgAwIBAgIJAMHHZhUAmSR6MA0GCSqGSIb3DQEBCwUAMIGlMQswCQYD
    VQQDDAJDQTEXMBUGCgmSJomT8ixkARkWB3ZzcGhlcmUxFTATBgoJkiaJk/IsZAEZ
    FgVsb2NhbDELMAkGA1UEBhMCVVMxEzARBgNVBAgMCkNhbGlmb3JuaWExJzAlBgNV
    BAoMHnZjYXBwcHJkcHNjLmN5dC5jb25jaGF5dG9yby5jbDEbMBkGA1UECwwSVk13
    YXJlIEVuZ2luZWVyaW5nMB4XDTE3MTIwMTE3NTExMVoXDTI3MTEyNjE3NTExMVow
    NjEnMCUGA1UEAwwedmNhcHBwcmRwc2MuY3l0LmNvbmNoYXl0b3JvLmNsMQswCQYD
    VQQGEwJVUzCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBAJseMJySBSCx
    +9cHt0MG27OaA0oLZ8GN/Yn3Mr0MyfIzrgL3wo7DGww3kRvD+k1g2TVHYi8fojY7
    rdMkr/IrmgcY+9VxaNVBWub5A2aVZgffbRYpOprFRs8aKSlb6ltbsJ7u5beHAz0A
    wFBdXs3ei8hJhUcD8tO0Y49zOhrXxGncVjeSmsIMo4yz/9DSWM/Cp7GXnaNyRUe7
    xFsU/cz5O7eH0jJMYUVziLaQqeN5SEFLFi931PV7mA+LnIxJ6i5iTSw8aK5YmgMr
    6BqhtAlAABe9x8KAzgvJL9TcZR6DN/96RKL/c6VRWD9wjUi9qJ/7XSi6YLHLjTjV
    uNRzuxeBpbECAwEAAaN6MHgwCwYDVR0PBAQDAgOoMCkGA1UdEQQiMCCCHnZjYXBw
    cHJkcHNjLmN5dC5jb25jaGF5dG9yby5jbDAdBgNVHQ4EFgQU2KrlhwvzB9dNIbFB
    HV8vka4ZEoQwHwYDVR0jBBgwFoAUKDE+vN0gyUrVW6utKc7t/bHFvP0wDQYJKoZI
    hvcNAQELBQADggEBAC+gNpaPWFNAXc3boyhziJX4zd9YCJTVddilrRzCaJ4Kgr8s
    kR9mKP5c1fDzZKsdEWVIKfoAyTcVgVwW5uYQbqngaJglSD8jsYwbVDEkQyQQ15tx
    VHKRXKcB4ujB8MF48D/R7syRAjojqV8kJk/TOnzLTSO7atiH2VcL0jJAgY9G//pO
    dTN3fjd1BOSw9BjknCeCfiOFBxTALWYM0fMzvxx3mlkMyowFntzF4bhQo/kS0QiK
    MStDpT/RLIUfh0MHwPzrhl1saumpvDy06LFO5C4B/ms3VfDr4pJuICdfQxvFU23E
    dMngxvcuYsJxflwvkcEbyxuSvNywicGxY0stZnY=
    -----END CERTIFICATE-----
    subject=/CN=psc-01.example.com/C=US
    issuer=/CN=CA/DC=vsphere/DC=local/C=US/ST=California/O=psc-01.example.com/OU=VMware Engineering
    No client certificate CA names sent
    Peer signing digest: SHA512
    Server Temp Key: ECDH, P-256, 256 bits
    SSL handshake has read 1469 bytes and written 433 bytes
    New, TLSv1/SSLv3, Cipher is ECDHE-RSA-AES256-GCM-SHA384
    Server public key is 2048 bit
    Secure Renegotiation IS supported
    Compression: NONE
    Expansion: NONE
    No ALPN negotiated
    SSL-Session:
        Protocol  : TLSv1.2
        Cipher    : ECDHE-RSA-AES256-GCM-SHA384
        Session-ID:
        Session-ID-ctx:
        Master-Key: B1BCCCAA8CF4244D1F84A751EF621AFF07730276988A6033DBF828D8B0C9F441A39B1FA64F8059E545BE0179918EA0B4
        Key-Arg   : None
        PSK identity: None
        PSK identity hint: None
        SRP username: None
        Start Time: 1512420236
        Timeout   : 300 (sec)
        Verify return code: 21 (unable to verify the first certificate)
  • 2.  RE: Problem migrate PSC embedded to external PSC - Certificate problem SSL 6.5U1 - HELP!!!!!
    Best Answer
    Posted Dec 06, 2017 01:03 PM
    I found the solution.
    The problem happens that the update to 6.5U1 does not copy the new certifying entities in the /etc/ssl/certs location, compares the number of certificates with a new 6.5U1 vicenter and 12 certificates were missing, this I guess is a BUG of the upgrade.
    After copying the remaining certificates the problem disappeared.
    :smileyhappy::smileyhappy::smileyhappy::smileyhappy::smileyhappy:
    these are the lost certificates
    /etc/ssl/certs/5e03e64c.0
    /etc/ssl/certs/5e03e64c.r0
    /etc/ssl/certs/6bfe6153.0
    /etc/ssl/certs/6bfe6153.r0
    /etc/ssl/certs/7d801d2d.0
    /etc/ssl/certs/7d801d2d.r0
    /etc/ssl/certs/c5214e96.0
    /etc/ssl/certs/c5214e96.r0
    /etc/ssl/certs/dfda8db2.0
    /etc/ssl/certs/dfda8db2.r0
    /etc/ssl/certs/e65bea3e.0
    /etc/ssl/certs/e65bea3e.r0
    SSL-Session:
        Protocol  : TLSv1.2
        Session-ID:
        Session-ID-ctx:
        Master-Key: 41DE589E24BD87140C47DD97DB1233BF770D5EE636594F5AD26C24D38F295D7A8683CBB797D6F5CE9AFBBF8A21C93A6C
        Key-Arg   : None
        PSK identity: None
        SRP username: None
        Start Time: 1512564521
        Timeout   : 300 (sec)
        Verify return code: 0 (ok)
  • 3.  RE: Problem migrate PSC embedded to external PSC - Certificate problem SSL 6.5U1 - HELP!!!!!
    Posted Jan 04, 2018 12:05 PM
    Hi dcisternas
    I've got the same exact problem, forgive me for being a bit slow. I can see that you copied the missing certs to "/etc/ssl/certs/" (1) Where did you copy them from i.e the Ext PSC or vCenter? and from which folder? (2) Where did you copy them to i.e Ext PSC or vCenter?
    Many thanks in advance
  • 4.  RE: Problem migrate PSC embedded to external PSC - Certificate problem SSL 6.5U1 - HELP!!!!!
    Posted Feb 02, 2018 05:14 PM
    I'm in the same boat.
    Do you have a walk through of what you did to fix it?  My vCenter died, so I redeployed a new vCenter with the same name, which had issues within the PSC because it was the same name.
    I deployed a new PSC with the same sso domain, but when trying to use cmsso-util repoint returns the same error as yours.  Looking at the certs in /etc/ssl/certs dirs on both the vcsa & psc, there are a ton of them in there.
    Thoughts?
