PowerCLI
  • 1.  Power CLi overcommit scripting help
    Posted Jul 29, 2019 02:06 PM
    I have this script and it works well for pulling this info 1 at a time for each cluster. I am trying to figure out how I can automate it so that I can pull all clusters in my vcenter at once, possibly creating a single spreadhseet with multiple tabs for each cluster. Any help would be greatly appreciated.
    # PowerCLI Script to check Host Overcommitment (CPU & Memory)
    # Select which vCenter you want to connect to
    # Build array for each vCenter
    Write-host "Select which vCenter to connect to:"
    Write-Host ""
    Write-Host "1. spvcenter11"
    Write-Host "2. srvcenter11"
    Write-Host "3. sdvcenter11"
    $Ivcenter = read-host “Select a vCenter Server. Enter Number:“
    if ($Ivcenter -match "1") {
    $vcenter = "spvcenter11"
    } elseif ($Ivcenter -match "2") {
    $vcenter = "srvcenter11"
    } else {
    $vcenter = "sdvcenter11"
    write-host ""
    Write-Host "You Picked: $($vcenter)"
    write-host ""
    start-sleep -s 3
    # connect to selected vCenter
    connect-viserver $vcenter
    # List Clusters
    write-host ""
    Write-host "Choose which Cluster you want to gather ratios on:"
    write-host "(it may take a few seconds to build the list)"
    write-host ""
    $ICLUSTER = get-cluster | Select Name | Sort-object Name
    $i = 1
    $ICLUSTER | %{Write-Host $i":" $_.Name; $i++}
    $HCLUSTER = Read-host "Enter the number for the host to Patch."
    $SCLUSTER = $ICLUSTER[$HCLUSTER -1].Name
    write-host "You have selected $($SCLUSTER)."
    start-sleep -s 3
    # Get CPU Overcommitment Information
    &{ForEach ($esx in (get-cluster $SCLUSTER | Get-VMHost)) {
    $vCPU = Get-VM -Location $esx | where {$_.PowerState -match "on"} | Measure-Object -Property NumCpu -Sum | select -ExpandProperty Sum
    $esx | Select Name, @{N='pCPU cores available';E={$_.NumCpu}},
    @{N='vCPU assigned to VMs';E={$vCPU}},
    @{N='Ratio';E={[math]::Round($vCPU/$_.NumCpu,1)}},
    @{N='CPU Overcommit (%)';E={[Math]::Round(100*(($vCPU - $_.NumCpu) / $_.NumCpu), 1)}}
    # Export results to Excel
    }} | Export-csv -path C:\OC\CPU_Overcommitment_$($SCLUSTER).csv
    # Get Memory Overcommitment Information
    $vMem = get-vm -location $esx | where {$_.PowerState -match "on"} | measure-object -property MemoryGB -SUM | Select -Expandproperty Sum
    $esx | Select Name, @{N='Total Memory Available';E={[Math]::Round($_.MemoryTotalGB),1}},
    @{N='Memory Assigned to VMs';E={$vMem}},
    @{N='Ratio';E={[math]::Round(100*($vMem / $_.MemoryTotalGB), 1)}},
    @{N='Memory Overcommit (%)';E={[Math]::Round(100*(($vMem - $_.MemoryTotalGB) / $_.MemoryTotalGB), 1)}}
    # Export results to CSV
    }} | Export-csv -path C:\OC\memory_overcommitment_$($SCLUSTER).csv
    # Disconnect from vCenter
    Disconnect-viserver $vcenter -confirm:$false
  • 2.  RE: Power CLi overcommit scripting help
    Posted Jul 29, 2019 02:17 PM
    If you install the ImportExcel module, you could something like this.
    A worksheet per cluster for CPU and Memory, and all in the same spreadsheet.
    The script will report on all clusters for all vCenters to which you are connected when running the script.
    Get-CLuster -PipelineVariable cluster |
    ForEach-Object -Process {
       $reportCpu = @()
       $reportMem = @()
       Get-VMHost -Location $cluster -PipelineVariable esx |
       $vCPU = Get-VM -Location $esx | where { $_.PowerState -match "on" } | Measure-Object -Property NumCpu -Sum | select -ExpandProperty Sum
       $reportCpu += $esx | Select Name, @{N = 'pCPU cores available'; E = { $_.NumCpu } },
       @{N = 'vCPU assigned to VMs'; E = { $vCPU } },
       @{N = 'Ratio'; E = { [math]::Round($vCPU / $_.NumCpu, 1) } },
       @{N = 'CPU Overcommit (%)'; E = { [Math]::Round(100 * (($vCPU - $_.NumCpu) / $_.NumCpu), 1) } }
       $vMem = get-vm -location $esx | where { $_.PowerState -match "on" } | measure-object -property MemoryGB -SUM | Select -Expandproperty Sum
       $reportMem += $esx | Select Name, @{N = 'Total Memory Available'; E = { [Math]::Round($_.MemoryTotalGB), 1 } },
       @{N = 'Memory Assigned to VMs'; E = { $vMem } },
       @{N = 'Ratio'; E = { [math]::Round(100 * ($vMem / $_.MemoryTotalGB), 1) } },
       @{N = 'Memory Overcommit (%)'; E = { [Math]::Round(100 * (($vMem - $_.MemoryTotalGB) / $_.MemoryTotalGB), 1) } }
       $reportCpu | Export-Excel -Path C:\OC\CPU_Overcommitment.xlsx -WorksheetName "CPU-$($cluster.Name)"
       $reportMem | Export-Excel -Path C:\OC\CPU_Overcommitment.xlsx -WorksheetName "Memory-$($cluster.Name)"
  • 3.  RE: Power CLi overcommit scripting help
    Posted Mar 03, 2021 12:17 AM
    LucD,
    How can I change this to show the overcommitment per Cluster. Say for instance I changed "WorksheetName" to "CPU" and added -Append. That lists all the hosts individually on one sheet, Then I added @{N ='Cluster'; E = { $_.parent}} to the Select and I get a column for cluster.
    But I want just at the cluster level, ie. One line per cluster.
  • 4.  RE: Power CLi overcommit scripting help
    Posted Mar 03, 2021 08:18 AM
    Something like this?
    Get-Cluster -PipelineVariable cluster |
       $reportCpu = @()
       $reportMem = @()
       $clusterCpuOC = @()
       $clusterMemOC = @()
           $clusterCpuOC += ($vCPU - $esx.NumCpu) / $esx.NumCpu
           $vMem = Get-VM -Location $esx | where { $_.PowerState -match "on" } | Measure-Object -property MemoryGB -SUM | Select -Expandproperty Sum
           $clusterMemOC += ($vMem - $esx.MemoryTotalGB) / $esx.MemoryTotalGB
       $cluster | Select @{N='Name';E={$cluster.Name}},
        @{N='CpuOvercommit';E={[Math]::Round(100 * ($clusterCpuOC | Measure-Object -Average).Average,1)}},
        @{N='MemOvercommit';E={[Math]::Round(100 * ($clusterMemOC | Measure-Object -Average).Average,1)}} |
       Export-Excel -Path C:\Temp\CPU_Overcommitment.xlsx -WorksheetName 'Cluster' -Append
       $reportCpu | Export-Excel -Path C:\Temp\CPU_Overcommitment.xlsx -WorksheetName "CPU-$($cluster.Name)"
       $reportMem | Export-Excel -Path C:\Temp\CPU_Overcommitment.xlsx -WorksheetName "Memory-$($cluster.Name)"
  • 5.  RE: Power CLi overcommit scripting help
    Posted Mar 03, 2021 03:13 PM
    LucD, As always thanks for the quick reply. I am amazed ( and maybe a bit frustrated at times) at how easily this comes to some people..
    So thanks for that update, that Cluster worksheet is almost to what I was trying to get to. And if I need to start a new post / question, just let me know.
    I have added a few more columns to be able to make the sheet read better, like the CPU / Memory sheets. If there is an overcommit, see what the actual values are.
    Below is my version.
    $cluster | Select @{N='Name';E={$cluster.Name}},`
    @{N='Hosts';E={(Get-VMHost -Location $cluster.Name).count}},
    @{N='VMs';E={(get-vm -location $cluster.Name).count}},
    @{N='pCPUs';E={$_.ExtensionData.Summary.NumCpuCores}},
    @{N='vCPU assigned to VMs';E={}},
    @{N ='CPU Ratio';E={},
    @{N='TotalMemory';E={$_.ExtensionData.Summary.TotalMemory}},
    @{N='AllocatedMemory';E={}},
    Export-Excel -Path $log -WorksheetName 'Cluster' -Append
    And output:
    NameHostsVMspCPUsvCPU assigned to VMsCPU RatioCpuOvercommitTotalMemoryAllocatedMemoryMemOvercommit
    workingworkingworkingworkingNeed help with expressionNeed help with expressionworkingSummary.TotalMemory gets a value but I guess I need to do a Math to get to GB, unless you know a better way.Need help with expressionworking
    I cant seem to come up with how to make the expressions get the info I am looking for. Thanks for your help.
  • 6.  RE: Power CLi overcommit scripting help
    Posted Mar 03, 2021 05:11 PM
    Check if this brings the values you want.
            $reportCpu = @()
            $reportMem = @()
            $clusterCpuOC = @()
            $clusterMemOC = @()
                    $reportCpu += $esx | select Name, @{N = 'pCPU cores available'; E = { $_.NumCpu } },
                    $vMem = Get-VM -Location $esx | where { $_.PowerState -match "on" } | Measure-Object -Property MemoryGB -Sum | select -ExpandProperty Sum
                    $reportMem += $esx | select Name, @{N = 'Total Memory Available'; E = { [Math]::Round($_.MemoryTotalGB), 1 } },
                $esxArr = Get-View -Id $_.ExtensionData.Host
                $vmArr = Get-View -Id $esxArr.VM
                $vmCpuCount = ($vmArr.Config.Hardware.NumCpu | Measure-Object -Sum).Sum
                $vmMemSizeGB = ($vmArr.Config.Hardware.MemoryMB | Measure-Object -Sum).Sum / 1KB
                $esxCpuCount = ($esxArr.Summary.Hardware.NumCpuCores | Measure-Object -Sum).Sum
                $cluster | select @{N = 'Name'; E = { $cluster.Name } }, `
                @{N = 'Hosts'; E = { $_.ExtensionData.Host.Count } },
                @{N = 'VMs'; E = { (Get-View -Id $_.ExtensionData.Host).Vm.Count } },
                @{N = 'pCPUs'; E = { $_.ExtensionData.Summary.NumCpuCores } },
                @{N = 'vCPU assigned to VMs'; E = { $vmCpuCount } },
                @{N = 'CPU Ratio'; E = { [math]::Round(100 * ($vmCpuCount / $esxCpuCount), 1) } },
                @{N = 'CpuOvercommit'; E = { [Math]::Round(100 * ($clusterCpuOC | Measure-Object -Average).Average, 1) } },
                @{N = 'TotalMemory'; E = { [math]::Round($_.ExtensionData.Summary.TotalMemory / 1GB, 1) } },
                @{N = 'AllocatedMemory'; E = { $vmMemSizeGB } },
                @{N = 'MemOvercommit'; E = { [Math]::Round(100 * ($clusterMemOC | Measure-Object -Average).Average, 1) } } |
