With all the missing files, I'm afraid that the only valid VM state that can be safely restored is the one from 08/15/2025 by editing the VM's configuratin (.vmx) file.
Please ensure that VMware Workstation is closed when you do this, so that the configuration file gets re-read after the manual modification.
Original Message:
Sent: Jul 20, 2026 09:53 AM
Subject: NEED HELP! VMWare workstation 17 pro not finding files
Thank you, please find the files attached.
Original Message:
Sent: Jul 16, 2026 02:43 PM
The small files are the 13 files without "-s0xx" in their file names. They are basically readable text files.
André
Original Message:
Sent: Jul 12, 2026 08:25 PM
Have quit a few, when you say small .vmdk files, what size qualifies as 'small'? Under 1MB or similar?
Original Message:
Sent: Jul 12, 2026 02:34 PM
Many of the required ...-s0xx.vmdk file s are missing.
Each virtual disk and each snapshot consist of a small descriptor .vmdk file (the ones without "s0xx" in its file name) and 25 data .vmdk files.
Unless you can still find the missing files on the ols PC or a backup, it may be possible to restore t least an earlier version of that VM.
Please compress/zip all the small descriptor .vmdk files along with the .vmx and .vmsd file, and attach the resulting .zip archive to your next reply.
André
Original Message:
Sent: Jul 11, 2026 06:25 PM
Finally got to run that report, please see attached. Have to either figure out how to open the vm, or extract the outlook files from the files. Greatly7 appreciate your help!!!
Original Message:
Sent: Jun 29, 2026 12:33 AM
Thank you for your reply. Will be happy to run that report, however, not sure how to do it, would you please explain? Thank you.
Original Message:
Sent: Jun 28, 2026 02:09 AM
Can you please clarify "then one of the snapshot files"?
There should (usually) be no need to connect to virtual disks/snapshots after moving the complete VM's folder to a new PC.
Please attach a completed file listing to your next reply, i.e. run dir *.* /oen > filelist.txt and attach the resulting .txt file to your reply.
André
