On Fusion 26h1u1 on Intel MAC I observed that closing a TCP connection will leave the guest TCP guest socket in FIN_WAIT_2 state. After analyzing the natd I confirmed that natd keeps the guest-side socket open and does not close it, verified with lsof (see below).
My diagnosys: because CLOSED socket is permanently readable: poll() reported it ready every iteration, the handler read() failed instantly, nothing was torn down, repeat at CPU speed. So seems a bug in the handling logic.
On the guest side:
# the leak specifically linux
sudo netstat -n |fgrep FIN_WAIT_2
# the leak specifically windows
netstat -n |find "FIN_WAIT_2"
On the Host side
sudo lsof -n -P -p $(pgrep -x vmnet-natd) | grep -c CLOSED
