VMware NSX
  • 1.  Facing problem while preparing vxlan using nsxramlclient
    Posted Sep 05, 2017 10:38 AM
    I am trying to use nsxramlclient for nsx automation. While using vxlanprep.py code, I am getting following error :
    reply: 'HTTP/1.1 400 Bad Request\r\n'
    header: Server:
    header: Cache-Control: no-cache
    header: Date: Tue, 05 Sep 2017 10:30:27 GMT
    header: Connection: close
    header: Strict-Transport-Security: max-age=31536000; includeSubDomains
    header: X-Frame-Options: SAMEORIGIN
    header: Content-Type: application/xml
    receive bad status code 400
    {'error': {'errorCode': '806', 'moduleName': 'core-services', 'details': 'Switch dvs-15718 does not contain all hosts in domain-c14823.'}}
    Although my cluster have one host only in it, also I can see that host is connected to dvs, still I am getting this error.
    On top of that I see this error with one cluster only, my other cluster with switch completely works fine.
    Any pointers what am I missing ?
    Here is the link for the test file shared in nsxramlclient.
    nsxramlclient/vxlanprep.py at master · vmware/nsxramlclient · GitHub
  • 2.  RE: Facing problem while preparing vxlan using nsxramlclient
    Best Answer
    Posted Sep 05, 2017 06:28 PM
    Double check your the VDS 'dvs-15718' and cluster 'domain-c14823' from vCenter MOB (Managed Object Browser) URL: https://<vCenterServerHostnameOrIP>/mob/?moid=<OBJECT_ID>
    https://<vCenterServerHostnameOrIP>/mob/?moid=dvs-15718
    https://<vCenterServerHostnameOrIP>/mob/?moid=domain-c14823
    or RVTools or PowerCLI
    If they are the correct VDS and cluster, try to prepare manually from the vCenter UI see if it's throwing similar error
  • 3.  RE: Facing problem while preparing vxlan using nsxramlclient
    Posted Sep 06, 2017 09:44 AM
    Seems I mixed up domain id, which was causing the error.
