vCenter
Expand all | Collapse all
According to the login problem of vCenter , help
  • 1.  According to the login problem of vCenter , help
    Posted Oct 12, 2018 02:13 AM
  • 2.  RE: According to the login problem of vCenter , help
    Posted Oct 12, 2018 02:47 PM
    can you check if all the vcenter/psc services are up and running?
    Is it an external psc/embedded psc?
    Is vcenter/psc deployed with ip/fqdn?
    - MS
  • 3.  RE: According to the login problem of vCenter , help
    Posted Oct 12, 2018 03:17 PM
    Did you install your vcenter using an ip address?
