Error details:
Compiling package 'uaa/8b830e3975971304f872c360cc3cf36d8eb24ad56388950e4dc018e3baa99dcf'... Skipped [Package already compiled] (00:00:02)
22:56:00
Compiling package 'bosh-gcscli/a03b1fc29fd357b8e3023193c87ae9ee49db052965efe5b3d9bff3538ed2df4b'... Skipped [Package already compiled] (00:00:00)
22:56:00
Updating instance 'bosh/0'... Failed (00:02:01)
22:56:00
Failed deploying (00:12:45)
22:56:00
22:56:00
Cleaning up rendered CPI jobs... Finished (00:00:00)
22:56:00
22:56:00
22:56:00
Deploying:
22:56:00
Running the pre-start script:
22:56:00
Sending 'get_task' to the agent:
22:56:00
Agent responded with error: Action Failed get_task: Task c02e36fe-33c0-4a10-4bcd-da5122839ba2 result: 1 of 11 pre-start scripts failed. Failed Jobs: uaa. Successful Jobs: monit, registry, blobstore, nats, postgres-10, bpm, credhub, user_add, ca_certs, director.
22:56:00
Exit code 1
22:56:00
===== 2020-01-30 17:25:53 UTC Finished "/usr/local/bin/bosh --no-color --non-interactive --tty create-env /var/tempest/workspaces/default/deployments/bosh.yml"; Duration: 829s; Exit Status: 1
22:56:00
{"type":"step_finished","id":"bosh_product.deploying","description":"Installing BOSH"}
22:56:00
Exited with 1.could not execute "apply-changes": installation was unsuccessful
What i tried:
1) Tried to go into bosh and see the logs for UAA instance. But unable to log into BOSH. It was accessible yesterday before triggering the BOSH update.
Is it that the deployment failed i unable to log into BOSH ?
Fetching info:
Performing request GET 'https://xx.xx.xx.xx:25555/info':
Performing GET request:
Retry: Get https://xx.xx.xx.xx:25555/info: dial tcp xx.xx.xx.xx:25555: connect: connection refused
Exit code 1
Please suggest how to deal with it.
Thanks,
Sujith K
