Hello Aparna,
Thanks for contacting the Pivotal Support Community!. That said, I think this [1] what you're looking for.
Best regards.
[1]: https://gemfire-nc-100-dotnetdocs.docs.pivotal.io/
Does this support .Net Core (i.e Linux verison) as well? If so, what is the Nuget Package to be used?
Regards,
Aparna
Please have a look at System Requirements [1], you should find the answer to these questions there.
[1]: https://gemfire-native-cpp.docs.pivotal.io/101/gemfire-native-client-cpp/system_requirements.html
