I have following issue.
Registering client certificate
b49d8e41-68b8-41e3-8fe4-15de9dbe022a
Registration of client certificate is successful
Checking if client certificate is ready to be used
Client certificate is ready to be used
Creating Load Balancer
unknown error (status 201): {resp:0xc420312990}
and in stderr.
master/994cda09-ec01-4dff-9584-4af434bd1c27:/var/vcap/sys/log/pks-nsx-t-prepare-master-vm# more pre-start.stderr.log
ResourceDeleteFunc(): unrecognized resource type: LbProfile
time="2018-09-28T22:06:54Z" level=error msg="Failed to CreateLbTcpMonitor: &{LbActiveMonitor:{LbMonitor:{ManagedResource:{RevisionedResource:{Resource:{Links:[] Schema: Self:<nil>} Revision:<nil
>} CreateTime:0 CreateUser: LastModifiedTime:0 LastModifiedUser: SystemOwned:<nil> Description: DisplayName:lb-pks-5b82f22b-78bd-45b4-9b5f-acd778269a22 ID: ResourceType: Tags:[0xc42022c120]} Res
ourceType:LbTcpMonitor} FallCount:3 Interval:10 MonitorPort:8443 RiseCount:3 Timeout:10} Receive: Send:}\n" pks-networking=networkManager
Error: unknown error (status 201): {resp:0xc420312990}
Usage:
pksnsxcli create [flags]
Flags:
--floating-ip string PKS cluster's instance UUID
-h, --help help for create
--instance-id string PKS cluster's instance UUID
--loadbalancer-name string Name of the load balancer
Global Flags:
-c, --client-cert-path string Client certificate for communication with NSX manager
-k, --client-key-path string Client private key for communication with NSX manager
--insecure Do not validate NSX manager's certificate (default true)
--nsx-ca-cert-path string NSX manager's CA certificate path
--nsx-manager-host string Hostname of NSX manager
--t0-router-id string T0 router ID
