VMware GemFire
 Removing record with space character from gemfire using gfsh
Selvakumar Murugesan's profile image
Selvakumar Murugesan posted Mar 28, 2019 10:51 AM
Dear All,
We have inserted the record which has trailing spaces('JP3758190007/106    ') that we couldn't remove by using gfsh. Please advise what query do we need use to achieve the same.
Query which we tried to delete with no luck:
remove --region=/INSTR_EAI_TEMP --key='JP3758190007/106    '
query --query="select tpaInstrumentId from /INSTR_EAI_TEMP where tpaInstrumentId='JP3758190007/106    '" ​
Thanks and Regards,
Selva Kumar M.
Rajiv CE's profile image
Rajiv CE
Hi Selva,
I tried to insert the record with key 'JP3758190007/106   ' and i was able to remove the record successfully. See the attached snapshot.
Which version of gemfire are you using.
Regards,
Rajiv
Hello Rajiv, We are using gemfire 8.2 version . Thanks and Regards, [cid:image007.png@01D1C7A3.D96B2750] SELVA KUMAR MURUGESAN MFS SD Ph :+91 44 6118 0267(extn:80267) Emergency Callout +91-44-61180277/+91-44-71080277 [cid:image005.jpg@01D17BA8.11897BC0] : PARIS BP2S MFS SERVICE DELIVERY
Juan Cassella's profile image
Juan Cassella
Hello SelvaKumar,
Thanks for contacting the Pivotal Support Community.
My name is Juan José Ramos Cassella, and I am a GemFire Technical Support Engineer with Pivotal.
That said, and adding to what Rajiv previously stated, the remove command seems to be trimming the actual value used for the --key parameter, so you won't be able to remove this particular entry within GemFire SHell. You can, however, write a really simple java client to delete the entry:
public static void main(String[] args) throws Exception { ClientCache cache = new ClientCacheFactory(). set("log-level", "config"). set("cache-xml-file", "client-cache.xml"). create();   try { Region<?, ?> region = cache.getRegion("INSTR_EAI_TEMP"); region.remove("JP3758190007/106 "); } finally { if (cache != null) cache.close(); }   System.exit(0); }
Hope this helps.
Best regards.
