VMware Tanzu Application Service for VMs
 PKS Cluster not created on VMware with Standard vCenter Networking PCF Ops Manager v2.2-build.292; PKS v1.0.0-build.311
SRE Coinone's profile image
SRE Coinone posted Jul 09, 2018 05:14 AM
pks status
Plan Name:        small
UUID:           00b468ee-71e3-4246-94c7-c48cfb5b5e19
Last Action:       CREATE
Last Action State:    failed
Last Action Description: Instance provisioning failed: There was a problem completing your request. Please contact your operations team providing the following information: service: p.pks, service-instance-guid: 00b468ee-71e3-4246-94c7-c48cfb5b5e19, broker-request-id: d9bd6318-a20c-4b17-9e61-ae7007038d95, task-id: 26, operation: create
bosh task log
Using environment '10.250.211.11' as user 'director' (bosh.*.read, openid, bosh.*.admin, bosh.read, bosh.admin)
Task 26
Task 26 | 01:29:22 | Preparing deployment: Preparing deployment (00:00:01)
          L Error: Duplicate variable name '/dns_api_tls_ca'
Task 26 | 01:29:23 | Error: Duplicate variable name '/dns_api_tls_ca'
Daniel Lynch's profile image
Broadcom Employee Daniel Lynch
Hi Coinone,
This is a known issue with Opsman 2.1.7 and 2.2.
SRE Coinone
Hi Dan,
Thank you for your reply.
By the way we use Ops Manager v2.2-build.292 already.
We found that recently there were source code changes in cf bosh kubo-deployment and some difference between cf and pivotal-cf bosh kubo-deployment.
cf: https://github.com/cloudfoundry-incubator/kubo-deployment/blob/master/bosh-deployment/runtime-configs/dns.yml
pivotal-cf: https://github.com/pivotal-cf/pks-kubo-deployment/blob/master/bosh-deployment/runtime-configs/dns.yml
Could you look into it more?
Thanks,
Coinone
Hi Coinone,
Yes this is a known compatibility issue with opsman 2.1.7 and 2.2. The fix for this is targeted in PK 1.1.1 release that we expect to have available on pivnet soon. We apologize for any inconvenience this may have caused.
best regards
David Holder's profile image
David Holder
Probably nothing new, but can confirm I get the same issue with PCF Ops Manager v2.2-build.292 and PKS v1.1.0-build.311.
Is there any workaround currently, or do we have to wait for PK 1.1.1?
root@ubuntu_1804:~# pks cluster k8s-cluster-01   Name: k8s-cluster-01 Plan Name: small UUID: 584ff638-6f84-48bf-a5fd-90cc484f8d8e Last Action: CREATE Last Action State: failed Last Action Description: Instance provisioning failed: There was a problem completing your request. Please contact your operations team providing the following information: service: p.pks, service-instance-guid: 584ff638-6f84-48bf-a5fd-90cc484f8d8e, broker-request-id: de31d26b-424b-4b5e-96e2-6878b5e5dc28, task-id: 84, operation: create Kubernetes Master Host: pks-cluster-01 Kubernetes Master Port: 8443 Worker Instances: 3 Kubernetes Master IP(s): In Progress   root@ubuntu_1804:~# bosh task 84 Using environment '172.16.10.200' as client 'ops_manager'   Task 84   Task 84 | 18:33:01 | Preparing deployment: Preparing deployment (00:00:01) L Error: Duplicate variable name '/dns_api_tls_ca' Task 84 | 18:33:02 | Error: Duplicate variable name '/dns_api_tls_ca'   Task 84 Started Tue Jul 10 18:33:01 UTC 2018 Task 84 Finished Tue Jul 10 18:33:02 UTC 2018 Task 84 Duration 00:00:01 Task 84 error   Capturing task '84' output: Expected task '84' to succeed but state is 'error'   Exit code 1
Bikram Singh's profile image
Bikram Singh
I am experiencing the same issue with PCF Ops Manager v2.1.7 and PKS v1.1.0-build.311 on VMware vSphere 6.5 . It would be good If we have any workaround till PKS 1.1.1 is released?
λ ~/Downloads  pks cluster pksk8scluster
Plan Name:        small
UUID:           bc15efcc-67a2-4636-a377-1bee2e98c9b3
Last Action:       CREATE
Last Action Description: Instance provisioning failed: There was a problem completing your request. Please contact your operations team providing the following information: service: p.pks, service-instance-guid: bc15efcc-67a2-4636-a377-1bee2e98c9b3, broker-request-id: d081167e-6083-4a4e-8fda-566fa173005f, task-id: 225, operation: create
Kubernetes Master Host:  pksk8scluster.itp-inc.com
Worker Nodes:       1
ubuntu@bosh-stemcell:~$ bosh -e vmware task 225
Using environment '10.9.85.16' as user 'director' (bosh.*.read, openid, bosh.*.admin, bosh.read, bosh.admin)
Task 225
Task 225 | 07:47:30 | Preparing deployment: Preparing deployment (00:00:01)
Task 225 | 07:47:31 | Error: Duplicate variable name '/dns_api_tls_ca'
Task 225 Started Thu Jul 12 07:47:30 UTC 2018
Task 225 Finished Thu Jul 12 07:47:31 UTC 2018
Task 225 Duration 00:00:01
Task 225 error
Capturing task '225' output:
 Expected task '225' to succeed but state is 'error'
Exit code 1
PKS 1.1.1 tile was released today and is currently available on pivnet.
