Retrieve the following:
Multiple providers of type 'database' found for consumer link 'database' in job 'bbr-cloudcontrollerdb' in instance group 'backup-prepare'
this will occur from errand bootstrap
any ideas ?
solved it by removing the Loadbalancer ip from the database Proxy configuration Setting and updarting TLS Settings
Glad you got the issue resolved, and thanks for posting the resolution here for others!
