We use both standard and distributed switches in our labs and both work fine. Just make sure you select the correct network when deploying the OVF. Aside from that, just make sure that your IP settings are correct.
Anyway, there's two things that can go wrong here.
1.) You configure the OVF, deploy it, it starts & there are -no- networks settings.
2.) You configure the OVF, deploy it, it starts & there are network settings but they don't work.
We need to figure out which, so once the VM finishes starting. Login & run `ifconfig` to see the status of things & update here with what you find.
