VMware Tanzu Kubernetes Grid Integrated Edition
 Onprem installation seems to be having inconsistent host name resolution issues. Is there a way that I can overwride the hostnames
Sarma K's profile image
Sarma K posted Oct 26, 2018 08:56 AM
I am trying to setup greenplum on onprem k8s cluster. I am hitting with an SSH connection issue with the host:
ssh: Could not resolve hostname segment-a-0.agent.default.svc.cluster.local: Temporary failure in name resolution
But the name resolves when I manually tried with ssh and also nslookup.
I had to add the following entries into the master-0 node's /etc/hosts
10.42.18.14   master-0.agent.default.svc.cluster.local    master-0
10.42.19.12   master-1.agent.default.svc.cluster.local    master-1
10.42.15.12   segment-a-0.agent.default.svc.cluster.local   segment-a-0
10.42.20.12   segment-b-0.agent.default.svc.cluster.local   segment-b-0
Without this, the script (/home/gpadmin/tools/wrap_initialize_cluster.bash) is trying to access the nodes using with hostname sometimes and with FQDN sometimes.
Errors something like this,
"stderr='pg_basebackup: could not connect to server: could not translate host name "master-0" to address: Name or service not known"
indicates that there seems to be some inconsistency in the naming.
May I know if this is a known issue or if there is a workaround?
Thanks
Mark Nagle's profile image
Broadcom Employee Mark Nagle
Hi Sarma,
Kubernetes internal name resolution is done by the kube-dns pod. In PKS this can be found in the kube-system namespace. Run the following to see the current state of the kube dns pod.
kubectl get pods -n=kube-system
Regards,
Mark Nagle
Sarma K
Hi Mark,
kube-dns is all good. I was able to resolve the hostnames of the pods from within all the green plum pods...
