The gpmon (the master process) will restart a missing worker (gpmon).
You might want to check /var/log/messages or dmesg to see if the worker has failed for some reason.
You may also be able to check the gpperfmon logs for the status of the worker on that host.
There is a gpperfmon directory for every segment on that host and a gpsmon log on the master.
