Welcome!
 Fresh Foundation building with Concourse
p kumar's profile image
p kumar posted Feb 07, 2019 12:55 PM
Hi ,
We are in plan of building brand new foundation (2.4) .
So , It is possible to implement concourse for building brand new foundation?
Or Concourse is only used to upgrade/update the existing foundation?
Please provide some inputs details on this.
Samrat Bhattacharjee's profile image
Yes Concourse can be used to build a new foundation. You can check https://network.pivotal.io/products/pcf-automation/.
You can download the pipelines and use it to create a new foundation. However it contains default setting if you wish to have some specific setting you need to customize.
