SAN Health Utility
Contributor
I am using old version of SAN Health(4.0.5) .And i need help to upgrade to latest version with step.
I created the file .BSH using an old version (4.0.5) of SAN Health. The latest version is available for download from https://urldefense.proofpoint.com/v2/url?u=http-3A__www.brocade.com_sanhealth&d=DwICAg&c=jf_iaSHvJObTbx-siA1ZOg&r=I6E4WdVrF95oyhKgmlWw9cnmLv3graWbo33zD4yFziM&m=cER6_RKurVZP2oWCYLvdVvwM5LZJhYB2QSVz6H3Ddjc&s=-h0uHDzULHdSPJfykqwF_yPDCLm2_eoSYXQ49u83qgk&...
So i need to upgrade my existing SAN HC software to this latest , so could you help me to download the exact software and get it installed and finally run it . As this is bit important task for our account so would need this upgrade soon and run the report using the new HC tool. Also do we need license for this , if so from where we should be getting . I am already using this tool but a older version.
External Moderator
Re: I am using old version of SAN Health(4.0.5) .And i need help to upgrade to latest version with step.
sharmab@1983
SAN Health is FREE, no License is required.
just download latest release and start the installer, there are not upgrade path required.
http://www.brocade.com/en/support/support-tools/support-download-san-health-diagnostics-capture.html
TechHelp24
Contributor
Thanks for the response Antonio. Now could you please check if i download this current version and install it on our Storage management server(Windows 2003 R2 with 8 GB RAM ) ? And does installing this software would case any Production Server to reboot ? It means does applying the latest SAN HC needs reboot of the windows servers ?
Moderator
SAN Health won't require a reboot. It really is as simple as a 10 second download and a 30 second install. Please download the latest version from http://www.brocade.com/en/support/support-tools/support-download-san-health-diagnostics-capture.html.
Contributor
Thanks . I have to generate the SAN HC report for 6 director/switches , out of which 4 x brocade & 2 are MCdata. We are aware that they are very old and unsupported version . So could you please let me know whether the current version of  "Brocade SAN Health Diagnostics Capture" would support this switches/directors and would fetch the complete switch port details ,including the correct amount of fibre details for procuring new switches and cables etc.
1.Brocade 48000 (Model 2109-M48)  Firmware ver=FOS v 6.1.0c
2. McData Intrepid 6140 (Model 2027-140) . Firmware ver=09.07.02.1
Moderator
Yes. You can see the supportability matrix on the SAN Health Online Help at https://community.brocade.com/t5/SAN-Health-Utility/SAN-Health-Online-Help/ta-p/3607.
External Moderator
Re: ISL to be set-up with new Brocade switches
sharmab@1983
are you question - both from March 5, and latest Post today - related to SAN-Health ?
TechHelp24
Contributor
Hi Antonio,
Yes please will you be able to help me ..
External Moderator
sharmab@1983
what kind of impact do you have with SAN-Health ?
TechHelp24
External Moderator
sharmab@1983
you Thread is a bit confused, for this reason I've moved part of  topit in New Thread
https://community.brocade.com/t5/Fibre-Channel-SAN/Re-ISL-to-be-set-up-with-new-Brocade-switches/m-p/95961#M27774
for question concerning you ISL config / issue or whatever, continue to post with exact questionin New Thread URL above
thank you.
TechHelp24
