Management Software
Regular Visitor
how to manage default switch SNMP string using Brocade Network Advisor
Does anyone has a procedure to change  default switch  SNMP sting to custom a string using  Brocade Network Advisor
Broadcom Moderator
Re: how to manage default switch SNMP string using Brocade Network Advisor
Hello,
Better is to do it on the switch directly with CLI.
You can also use webtools:
- Configure
- Switch Admin
- Show Advanced Mode
- SNMP
