Management Software
Occasional Contributor
SAN Network Advisor 12.4.2 (and now 14.01) running slow, stuck hourglass cursor and clicking on items wont work?
As the title states, we have been running SAN Network Advisor on the same server for years without issue.  We ~6 months ago upgraded to 12.4.2 without issue.  Even as recent as two days ago everything was running great.
Today I log in and search takes forever, performance is crap, and the hourglass cursor will not go away.  Most annoying is say I click a WWN and want to edit properties to give an alias?  Yeah it randomly opens some other item without rhyme or reason.
Ok, so I'll reboot... nothing.  Ok, I'll upgrade to 14.01, same problems.  After another reboot the DB has issues starting and the services wouldnt manually start, another reboot fixed that.
Now regardless of what I try and do the hourglass cursor never leaves, performance is always crappy, and things like clicking on an item to edit it is messed up.
Any ideas what is going on and happening?
Broadcom
Re: SAN Network Advisor 12.4.2 (and now 14.01) running slow, stuck hourglass cursor and clicking on items wont work?
Since the system has been running fine up until now, I'd be checking things like hardware - e.g. a dying disk. Things like the DB & services not starting needs investigation - look at the logs, see what it says about why it didn't start.
I would also look at what other software changes have been made recently - e.g. OS updates.
Broadcom Moderator
May I ask, what are the hardware Specifications of the server on which you are running BNA?
(Processor, memory, Disk Space, Operating System)
Any and all information provided by me is for entertainment value and should not be relied upon as a guaranteed solution or warranty of serviceability. All systems and all networks are different and unique. If you have a concern about data loss, or network disconnection, please open a TAC service request for service through Brocade, or through your OEM equipment provider. If this provided you with a solution to this issue, Please mark it with the button at the bottom "Accept as solution".
