Management Software
Occasional Contributor
SAN Network Advisior 14.4.1 (pro - not plus) - View SAN Storage HPE MSA 2040
I am using the SAN Network Advisor Pro (not plus). In the SAN view, under ' View all ', I see only the SAN switches and the host. Only if I select a port directly, I also see the SAN storage (HPE MSA 2040). Is it possible to view the storage directly? I select in the properties port display--> Attached ports will show me the SAN storage under "symbolic name".
Thanks, Ralf
