Management Software
Anonymous
Network Advisor v11.3 problem
Hi
I have a customer with Network Advisor v11.3 installed. When he tries to access historical data, he get a pop-up message "No Data points found for the selection". Does anyone have any ideas?
Many thanks
Ian
Anonymous
Re: Network Advisor v11.3 problem
Is your customer seeing this after a recent upgrade from a prior version of Network Advisor to 11.3 ?
Anonymous
Yes, they upgraded from 11.2 to 11.3.
Anonymous
Sounds like the DEFECT000420202 noted in BNA 12.0 release notes .
Anonymous
So is fixed in BNA 12.0 .
Release Notes attached .
Anonymous
Many thanks for pointing that out. I'll pass info on to the customer.
Anonymous
Hello,
I have the same issue which is mentioned by the author.
But we are with BNA 12.
We had performance issue a month ago and there has performance logs available, but now I noticed that when I try to get historical data on any of the switches in the environment, I'm receiving the same message:
Also I noticed that the real time graphs doesn't show anything, Like the ports are not using at all. But when I verified on the switches the traffic is shown.
Does anyone has an idea where the problem is?
Thank you.
Occasional Contributor
Hi all,
We are having the same exact problem with BNA v12.0.1.
Any news?
Thanks in advance
New Contributor
Same issue on BNA 12.2.0
Former Brocadian
folks this would normally indicate that BNA is not getting the relevant performance data from the network devices in scope for that time period for some reason - possibly SNMP credentials issue? Presumably they have been discovered correctly?
