Management Software
Anonymous
Help: how to start rpcd after upgrade FOS 7.0.1
Hi to all,
I upgrade FOS from 6.4 to 7.0.1,  then SMI-agent can't connect to switch.
G3-08-SAN:FID128:admin> netstat -na | grep LISTEN
tcp        0      0 0.0.0.0:512             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:513             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:514             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:37              0.0.0.0:*               LISTEN
tcp        0      0 127.0.0.1:199           0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
tcp        0      0 :::80                   :::*                    LISTEN
tcp        0      0 :::22                   :::*                    LISTEN
tcp        0      0 :::23                   :::*                    LISTEN
unix  2           STREAM     LISTENING     1457   /tmp/webtools/tmp_0/31bafdb358bb3c0ce85fb24606c239e6
unix  2           STREAM     LISTENING     719    /tmp/ipadm_getset
unix  2           STREAM     LISTENING     721    /tmp/ipadm_notify
unix  2           STREAM     LISTENING     1509   /tmp/rcs_query0
G3-08-SAN:FID128:admin> ipfilter --show
Name: default_ipv4, Type: ipv4, State: active
Rule Source IP    Protocol   Dest Port   Action
1     any                                            tcp       22     permit
2     any                                            tcp       23     permit
3     any                                            tcp      897     permit
4     any                                            tcp      898     permit
5     any                                            tcp      111     permit
6     any                                            tcp       80     permit
7     any                                            tcp      443     permit
8     any                                            udp      161     permit
9     any                                            udp      111     permit
10    any                                            udp      123     permit
11    any                                            tcp      600 - 1023     permit
12    any                                            udp      600 - 1023     permit
Name: default_ipv6, Type: ipv6, State: active
1     any                                            tcp       22     permit
2     any                                            tcp       23     permit
6     any                                            tcp       80     permit
rpcd can't start, no port 897 LISTEN
how to start rpcd ?
Could you help me to discovery the problem?
thanks
wanglifu
Anonymous
Re: Help: how to start rpcd after upgrade FOS 7.0.1
Hello wanglifu,
I am not sure if this note helps and if it fits to your problem.
SMI Compatibility
It is important to note that host SMI-S agents cannot be used to manage switches running FOS v7.0.
If users want to manage a switch running FOS v7.0 using SMI-S interface, they must use Brocade Network Advisor’s integrated SMI agent.
Regards,
Andreas
Anonymous
I have installed NA 11.1.4, but I can't connect to a switch that running FOSv7.0.1.
Anonymous
Hi,
I would suggest to provide a fabric name as well try to set the SNMP settings manual.
Check on the SAN Switch the SNMP settings. The command on the switches is snmpconfig --show snmpv1 or snmpv3.
Make sure that the BNA server can run successful SNMP requests.
You can check this with common SNMP tools.
I hope this helps,
Andreas
